Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 11-23-2011, 03:24 PM
old_master's Avatar
Advisor/Moderator
2001 ZX3 serp belt tensioner
Replaced the original tensioner at 211,000 miles as a preventive maintenance measure with a Dayco tensioner. Now it has 276,000 miles and I have replaced it 5 times since. They all have snapped in the same place. Replaced the belt each time. All of the pulleys are aligned properly and no binding or wobble in any of the pulleys. Any ideas? Different manufacturer? Thank God for the warranty, but I'm tired of replacing it every few months.
You have to know how it works,
to figure out why it doesn't.
Old 11-25-2011, 06:19 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 2001 ZX3 serp belt tensioner
I'd use a OEM tensioner this time! There are dealers online that sell at wholesale prices.
The Original 97Bird
Old 11-25-2011, 06:23 PM
old_master's Avatar
Advisor/Moderator
Is the arm that the pulley attaches to made out of aluminum or steel on the OEM?
Old 11-25-2011, 06:41 PM
97Bird's Avatar
I have no idea but you got 211,000 out of the last one!
The Original 97Bird
Old 11-25-2011, 06:43 PM
old_master's Avatar
Advisor/Moderator
I know... I was just trying to be proactive and avoid a problem, now I have 5 problems! Maybe I'll check with the dealer if this one takes a crap.
Old 05-09-2012, 09:21 AM
egc519mzl egc519mzl is offline
I just had mine replaced at 293K last week. I wonder how long it would last. One thing that I almost missed in the instruction on how to align the notch to the marker. You have to turn the tensioner (the one with hex hole) counterclockwise to align them. Again, I just had it replaced so let's see if I would encounter the same problem down the road.
02 Ford Focus @ 306K
97 G Voyager 3.3L V6 @ 122K. Trans leak fixed 5/2007
94 Jeep G Cherokee Laredo 5.2L V8 @ 159K re-fixed transfer case
last update : 01/23/2013
How to remove serp belt tensioner? jperitore Rodeo | Passport | MU 1 02-15-2008 09:02 PM
93 sunbird serp belt tensioner nifty General Discussion 4 09-30-2006 03:31 PM
Serp belt replace 1988 century, tensioner stuck ? jhilb Century 1 05-30-2005 06:05 PM
Timing belt tension spring's purpose AFTER belt install? Allen McCready Camry/Camry Hybrid/Vista 2 11-26-2004 11:42 PM
