Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 11-23-2011, 09:48 AM
rickyandtina rickyandtina is offline
Multiple problems 98 Chevy Silverado
I have a 98 Silverado. We have rebuild the 5.7 vortec motor and the 4L60E transmission. Everything is stock in the motor except we went with flat top pistons and we had it bored out 30 over and has a new fuel injector spider. Transmission was upgraded with 3-4 clutch pack. Has rebuilt torque converter and new park/neutral switch.
TRANSMISSION: From the day we put the transmission in we have had problems. SES light came on instantly. Going into default gear but not all the time. Turn truck off and it is fine. Throwing the PO785 code. We have checked the ignition switch and have changed both the 1-2 solenoids and one of the 3-2 downshift solenoids. Waiting for the other to come in.
DASH LIGHTS: When I turn my headlights on my dash lights blow a fuse. Radio works fine as do my turn signals. Have replaced fuses and the headlight switch. Still doing it.
MOTOR: The motor has a loopy idle mostly while truck is in gear. Truck also surges under a load like climbing hills, etc. At start up sometimes dies or the RPMs drop then pick right back up. Also gets horrible gas mileage, like 12 miles to gallon compared to 18 before we rebuilt the motor.
Any answers to any or all of our problems would be great. Have spent a great deal of money on this truck to get it right and getting very frustrated that things are not working out.
Old 11-23-2011, 10:26 AM
maxwedge maxwedge is offline
A990 racer
Re: Multiple problems 98 Chevy Silverado
First of all anything could be wrong with the the trans., who did the rebuild, done correctly? Look for an improperly seated main plug on the trans. A full trans scan can command those solenoids and check if all the connections are in place. Second, look for a pinched harness somewhere in the headlite/tailite circuit, maybe something done when the drivetrain was in and out? The engine performance, again many things can cause this, a full scan will look at sensor inputs, fuel trim and any other controls that affect mileage and performance. Can we assume none of these issues were there prior to all the work being done?
Old 11-23-2011, 02:40 PM
777stickman 777stickman is offline
Your rebuilt motor may need the CKP (Crank Position Sensor) Variation Relearn procedure. This will require a high end scan tool in the hands of a capable tech. This tool is also needed to set the base timing (Cam Offset or Cam Retard).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
2000 Chevy Silverado 4x4 tranny issue nymike Silverado 3 03-05-2010 08:31 PM
1995 chevy z71 instrument cluster problem BIGER_IN_TEXAS_Z71 Silverado 0 09-03-2009 04:22 PM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 07:28 PM
Multiple Problems Chevy Venture 2001 Peggums6 Venture 7 09-21-2007 10:11 PM
Multiple 98 Chevy Lumina 3.1L problems, any help welcomed embiber Lumina 2 01-31-2005 06:48 AM
