Old 11-20-2011, 01:44 PM
dallas_1982 dallas_1982 is offline
2.4l p301
I have a 2000 olds alero 2.4l. i get 2 codes p301 and pending code 301.
service engine light and trac off light. it runs rough, exhaust smells like fuel.
I have used a multimeter on the coils, checked the primary and secondary resistance on the coils and they check out fine. I have also changed the plugs, the wires, flipped the coils, switched the fuel injectors around, still no change. it has been this way for a few weeks now. once it did run normal, no lights, smooth running, it ran good for about 15min. then the lights came back on. any ideas?
Old 11-20-2011, 08:29 PM
Tech II Tech II is offline
Re: 2.4l p301
Is this the Ecotec engine or the Quad Four engine?
Old 11-21-2011, 10:07 AM
Re: 2.4l p301
2.4l LD9 quad 4
Old 11-21-2011, 04:39 PM
Re: 2.4l p301
is the [trac off] light related to the engine problem?
Old 11-22-2011, 08:03 AM
Re: 2.4l p301
Trac Off comes on when when a misfire code is set....
Replaced wires? There are no wires....unless you mean the boots..
Checking coil resistance is only one test.....need to check coil output, that takes a set of test wires.....
One thing this vehicle has a problem with, is the tower cover.....this is the cover that the coils sit in.....
If the misfire is on cylinder#1, compression is ok, a new A/c delco plug is in there, try swapping the coils in the housing.....if you still get a misfire on #1, could be the housing....
After replacing that, if you still have a misfire, could be an injector problem....but I'm leaning towards the cover...
The Following User Says Thank You to Tech II For This Useful Post:
dallas_1982 (11-22-2011)
Old 11-22-2011, 02:45 PM
Re: 2.4l p301
i will try a cover next.
Old 11-22-2011, 07:56 PM
Re: 2.4l p301
and misfire doesn't mean not fire? also previous owner didn't tighten up the brake caliper bolts and 1 fell out so i put a new one in then the trac light went off...for a half hour, also the cel wasn't flashing...but i am putting in a new coil housing cover tonight...so hopefully it will be fixed
Old 11-23-2011, 03:38 PM
Re: 2.4l p301
all fixed...thanks for the help
will a 2.4l nonturbo clutch fit in a 2.0l non turbo clipse420a Engine, Transmission and Drivetrain 5 03-11-2008 03:20 PM
2.2L to 2.4L swap - Can it be done? chadm_88 Cavalier 4 07-21-2007 03:26 PM
2.2l vs. 2.4l CAVI2nr97 Cavalier 2 06-19-2005 11:33 AM
96 Z24 2.4L Cold air intake Fit a '95 Z24 2.3L Zamir0884 Performance 0 05-12-2005 01:39 PM
2.2L into 2.4L/2.3L Schotty Cavalier 2 07-25-2004 09:22 PM
