Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 06-01-2003, 08:11 AM
Ram1 Ram1 is offline
Angry Overheating
I have a 1995 E150 it is running hot so I have change T-stat and water pump. but it is still running hotter than normal. Should you see flow in the radiator when cap is removed with T-stat in? And is 192 deg. T-stat to high?
Old 06-02-2003, 08:16 PM
pcv pcv is offline
All new vehicles now have to run normally high (to about 108C) due to emissions. Check your clutch fan, at the front of the engine to see if it is leaking fluid at the front of it. If it is, replace it. Also make sure you have no air lock in the cooling system.
Yes, you should see flow across the top or the rad when vehicle is hot. That confirms that your stat is open.
NOTHING LIKE AN OLD CAR.
Overheating...overheating...overheating... 92 Firebird Camaro Discussions 13 09-08-2006 11:16 AM
'92 dynasty...overheating...OVERHEATING yooperfly General Discussion 8 07-24-2005 10:04 PM
overheating, not overheating racandbb Caravan | Voyager 0 06-23-2004 07:59 PM
89 Cherokee overheating...and overheating... frakkis Cherokee 6 05-01-2004 11:54 PM
truck overheating but gauges do not indicate overheating wucus Explorer | Explorer Sport Trac 1 10-24-2003 04:04 PM
