Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 07-16-2005, 01:43 AM
yooperfly yooperfly is offline
'92 dynasty...overheating...OVERHEATING
'92 dodge dynasty overheating. All hoses are good and clamps are tight. Put in new thermostat. (thermostat housing good) Replaced radiator cap. Fan fuses and relays functioning.....fan kicks in wonderfully. No leaks anywhere and coolant is to proper levels. Head gasket is fine.......no antifreeze leaking into oil. Flushed out system completely. Coded the car and it showed no problems with any of the sensors. What else is there left to try? Please, someone out there.......have the next step for me. This whole problem is starting to make me mean!
Old 07-17-2005, 09:51 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: '92 dynasty...overheating...OVERHEATING
Is it blowing steam out at you? When you had all this stuff done, did you bleed out your cooling system? If you have air pockets in your fluid, it can cause an overheat condition to be read on your instrument cluster.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 07-18-2005, 02:07 AM
mr.avenger's Avatar
mr.avenger mr.avenger is offline
Send a message via AIM to mr.avenger
do you think it might be your radiator?, we jus thad a car in our shop today with the same exact problem you having everything was reading good everything hose wise fluids wise and air pockets wise was good and it ended up being a crap radiator and bam it fixed it instantly.... lemm eknow if ya find out...~mr.Avenger~
1995 DODGE AVENGER!
2.0 ltr. DOHC 420-a engine
Shaved door handles
Shaved gas filler tube(mounted in trunk)
Enkei demolisher 16" rims
Primer awaiting paint
Old 07-21-2005, 09:07 PM
Re: Re: '92 dynasty...overheating...OVERHEATING
Thank you for replying.......the only time that it blows out any steam is when radiator cap is taken off before it cools down properly. I have bled the system and "burped" it many times now. The *&$($&@&**( temperature gauge just keeps climbing and climbing.
Old 07-21-2005, 09:15 PM
Thank you for replying....I'm hoping that it is not the radiator. I know that it does not leak anywhere. I also know that it is as clean as a whistle. (I got frustrated to the max and dumped about 1/2 cup of muriatic acid into the water filled radiator, let it set for about 20 minutes, then flushed it again. The water came out pretty black. Then I dumped another 1/2 cup of acid into the water filled radiator and repeated the whole process......this time when I drained it, it came out crystal clear.) I know that the water is circulating properly. And I seem to be getting meaner by the hour 'cause I can't figure it out! Is there a sure-fire way of finding out if you have a bad radiator before you actually purchase and install a new one?
Old 07-21-2005, 10:50 PM
Try this, turn on your heat next time; if you smell antifreeze, your problem is a busted heater core. Make sure as well that you don't have antifreeze on your carpet.
Old 07-22-2005, 11:52 AM
I must be running out of options......have tried the heat. It brings the temp gauge down for about a minute, then it shoots right back up again. No smell, and no damp carpets inside the car. (I've had heater cores go before, and there is no mistaking that smell, or dampness in the car.) I'm positive that my heater core is fine. Is it possible that I do have a thermo sensor that is shot and coding the car is just overlooking it?
Old 07-23-2005, 08:16 AM
niccaleb112602 niccaleb112602 is offline
overheating
I would look at that head gasket again, i've seen so many gaskets pushing air into the cooling system but not blown enough to allow coolent to leak back into engine. Happened to a omni my ex had.
Old 07-24-2005, 10:04 PM
well, if I understand you correctly, forgive me if I sound retarded, but if you don't have any visible signs of coolant loss, I'd guess at a bad temperature sending unit. But that is assuming that everything is OK, no problems.
