Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-16-2003, 04:51 PM
wucus wucus is offline
truck overheating but gauges do not indicate overheating
Can anyone tell me why my truck is overheating but the gauges do not read that it is overheating. I have taken it to the shop and they say everything is okay but it continues to overheat. (steam coming from under hood) thanks.
Old 10-24-2003, 04:04 PM
V8X V8X is offline
Re: truck overheating but gauges do not indicate overheating
This is what you would at least check for a 1999 X.
There are two items you need to check. You have the thermostat, which sends the reading to the Gauge Cluster. You also have an ECT (Engine Coolant Temp. Sensor), which sends the actual temp to the Computer. Most likely you have a bad ECT, since youR gauge cluster isn't showing hot.
Hopefully this helps. Let us know of the results.
V8X
1999 Explorer Limited 5.0L AWD
1999 Ranger XLT 4.0L Off-Road Package
1996 Explorer XLT 4.0L 4X4
1993 Sentra SE-R 2.0
1985 Ranger XLT 2.8L 4X4
1969 Camaro RS 327ci
If you're wrong, I'll find out & correct you!
