Old 11-14-2011, 07:20 AM
rgs858 rgs858 is offline
trans cooling lines
Hello all can anyone tell me if you have to use preformed transmission cooling lines or can you use transmission rubber coolant hose to replace the coolant lines on a 2000 ford windstar?,,,thanks
Old 11-14-2011, 08:06 AM
12Ounce 12Ounce is offline
Re: trans cooling lines
I've never had to replace my tranny hose asseblies. If I had to, and I may as I replace my sub-frame sometime "soon", .... my first choice would be replacements from Ford. But if those were not available to me, I would have little problem using aftermarket hoses. The fluid pressures are not that great, so if you use hose made for the tast ... hot oil... and have leak-proof connections .... you should be OK.
Old 11-14-2011, 07:31 PM
wiswind wiswind is offline
Bulk transmission fluid hose will work.....It is what we use when we install a auxillary transmission cooler.
The factory size is 5/16"......if you cannot find that, 11/32" will work, but 3/8" is too big for the metal nipples (might come off).
Power steering uses 3/8"......but tranny uses 5/16"
On my '96, 1 end of each had a hose clamp, the other had a "permenant" crimp type of clamp.
I had to cut the crimp type clamp off in order to remove the hose at that end....and I used a normal hose clamp at both ends.
Take care to avoid having the hose rub anything rough or sharp......and to avoid having the hose hang down or be drawn too tight.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
trans cooling line busted the reverend Fiero 2 05-07-2007 08:22 AM
Trans Cooling Lines chrisant Corsica 2 08-30-2006 08:54 AM
Transmission fluid leaking from lower trans. cooling line @ radiator vincentvaldez Blazer 12 08-15-2006 11:54 AM
84 Olds Omega/AT 125C Trans cooling lines... tmy420 Omega 8 07-13-2006 09:45 AM
