Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 08-21-2006, 07:54 AM
chrisant chrisant is offline
Trans Cooling Lines
I have a 94 Corsica with a 3.1L 4T6x transmission. I cannot find the lines anywhere for this. Anyone know a place online to order them?
Old 08-29-2006, 08:30 AM
dewaynep dewaynep is offline
Re: Trans Cooling Lines
You can always replace the original lines with some steel brake line and transmission cooler hose. Leave the flare on the end you put the hose over so it holds tight. If you don't leave the flare, then double clamp the hose on both ends or it will slide off emptying your tranny of its fluid real quick. I had to do this on my 98 Skylark. It's been about 40k miles with no issues. Total cost is Under $15.
Old 08-30-2006, 08:54 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the tranny lines for the 4-speed trans are dealer only thru GM and the part numbers are as follows:
upper- 22651564
lower- 22651565
Both run only $21.82 retail, so they're not that expensive.
Just for reference, the 3-speed trans lines arethe same price, part numbers:
upper-22645906
lower-22645907
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
