wheel speed sensors
would the wheel speed sensors afftect both the abs/brake lights and the od/off light causing both to come on intermittenly?
Re: wheel speed sensors
ABS/brake lights yes; O/D light I don't think so.
I would think your problem is the Brake Pressure Switch under the brake reservoir leaking fluid (that would cause the level to drop and cause the brake light) into the Transmission Range Sensor on top of the transmission (causing the O/D light problem). Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
If you do end up checking the wheel sensors...
Here's a link to pics I took when cleaning and checking wheel speed sensors as part of my ABS diagnosis and repair project: http://good-times.webshots.com/album/559769331GYPtlJ
2000 Windstar LX 3.8 1995 Contour GL 2.5 1986 Mustang GT 5.0 --> Sold, but missed on sunny days |
I have actually taken it in for the recall and had the brake pressure switch replaced, the range sensor has been replaced and I have cleaned the wheel sensors (and since I cleaned them the ABS/Brake light comes on more often than before).
The reason I'm asking is that I had the transimission replaced twice and the O/D off, Brake and ABS lights still come on. The tranny shop has run the codes for the OD off light and all they'll tell me is that it is a TCC code. They cannot find the problem, they are thinking that I have a bad ABS module and that it could possibly be causing the OD off light to trigger. They won't touch it any longer until the ABS/Brake light issue is corrected. |
I'd be checking the neutral safety switch (TRS). You may just have an unrelated problem causing the OD light to flash.
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
