Old 11-10-2011, 09:35 PM
racer504 racer504 is offline
98 Astro rear axle seal leaking
A while back (while changing brakes) I noticed the passenger side axle seal was leaking. I had a good friend who is a mechanic change it for me. After a couple months I saw it was leaking again. This time we changed the bearing and seal. Now about 2 months later, it's leaking again.The axle surface seems to be OK. Not rusty or rough. We smoothed it up with some fine emery cloth before reassembly. Any ideas on what might be going on with this would be greatly appreciated.
Old 11-11-2011, 07:00 AM
snshddog snshddog is offline
Re: 98 Astro rear axle seal leaking
Make sure the vent tube is not plugged up. It can pressurise the inside and force fluid out. Check that the hose is good and that there is no sludge plugging up before that. the hose can be checked by blowing air through it, the fitting can be checked by using a piece of coat hanger or something thin enough to get in there but bend a little handle on it so you dont accidentily drop it in.
Old 11-11-2011, 01:05 PM
Originally Posted by snshddog View Post
Make sure the vent tube is not plugged up. It can pressurize the inside and force fluid out. Check that the hose is good and that there is no sludge plugging up before that. the hose can be checked by blowing air through it, the fitting can be checked by using a piece of coat hanger or something thin enough to get in there but bend a little handle on it so you dont accidentily drop it in.
Thanks snshddog, I'll check that.
Old 11-14-2011, 08:21 PM
I checked the tubing and vent tube and both are clear. Any other ideas?
Old 11-16-2011, 10:44 PM
Blue Bowtie's Avatar
Registered Offender
Yes. Either trim out the factory gasket or sealant that was used to seal the cover or install a FelPro cover gasket with the proper openings in the sides to allow oil relief:
The Following User Says Thank You to Blue Bowtie For This Useful Post:
racer504 (11-16-2011)
Old 11-18-2011, 11:18 PM
Blue Bowtie, I'm just curious as to how this might be causing a leak at the seal? Seems like if the gasket was blocking the oil flow to the bearings it would also be restricting flow to the seal. . Not questioning your knowledge here, just trying to gain a better understanding of the problem. Thanks for your help!
95 Suburban front differential axle seal leak jjwg3 C/K 10 12-07-2010 01:15 PM
Rear axle seal leak - Passenger bgrams01 Silverado 3 03-28-2010 10:35 PM
Rear differential CV axle seals leaking bochnak Explorer | Explorer Sport Trac 4 05-03-2007 07:55 AM
rear axle seal leak limacina Sierra 0 06-26-2006 10:48 PM
right axle seal leak Darkwing '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 04-03-2002 03:04 AM
