Go Back   Automotive Forums Car Chat > Lamborghini > Diablo
Old 06-01-2003, 01:33 AM
modman modman is offline
How do you reset the ABS light on the Diablo?
I was working on the rt wheel and I noticed the plug that goes to the ABS sensor was coming loose and the ABS light won't turn off even after turning the power off on the car using the knob behind the drivers seat. How do you reset the ABS warning light on the dash? it keeps buzzing on and off, stops, then repeats itself and it's annoying.
Old 06-04-2003, 06:27 PM
TTBADBOY TTBADBOY is offline
Im not exactly sure but I would try disconnecting the battery.I know its a pain but it should clear the code in the ECU.Maybe before that try pulling the ECU fuse,that should do it.My car did the same when I accidentally drove off with the emergency brake on.I just had to restart the car about 3 times (with the brake off this time "duh") and that turned it off.
Joe
01 Diablo 6.0
97 Viper GTS S/C
93.5 Supra T66
01 Lightning
Old 06-04-2003, 10:36 PM
I tried disconnecting all main fuses but that didn't work and I called Al Burtoni who services them and they said they use a laptop to turn off the signal and they said I believe it's with 98 and up models.
How do you reset check engine light on 2002 Mustang? Ballisitc Audio Mustang Talk 4 02-15-2009 06:51 AM
How To RESET Your Service Lights graymarki 7 Series 5 06-13-2007 08:50 PM
2001 Pontiac Aztec. How do you reset Chang Oil Light in message center oregon712 Aztek 3 02-27-2006 12:33 PM
How to reset brake warning lights? rus_grizzly Cutlass Series 1 06-26-2005 05:04 PM
How to reset oil service light 318i 1991 Earl Allen Automotive News Desk 1 06-24-2004 10:00 PM
