Go Back   Automotive Forums Car Chat > Toyota > Land Cruiser/LX470
Old 11-08-2011, 04:23 AM
kikkup kikkup is offline
bouncy/hard ride/ lexus lx 470
I have a 2001 Lexus lx 470, The ride is bouncy , I was going to change the fluid and when I went to syringe the old fluid out it had water mixed in with the fluid, I have new fluid but does anyone know the proper procedure for getting this out, and do I need to just drain the whole system, just need to know the right way to do this... Thanks Steve
Old 11-08-2011, 05:50 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: bouncy/hard ride/ lexus lx 470
If you are talking about replacing the brake fluid, you will need to replace all the old fluid if there is water contamination. Syringe out all the old fluid from the master cylinder and replace it with fresh fluid. Then bleed all the wheel cylinders until fresh fluid comes out. Since the new fluid is probably also now contaminated with some water (any contamination is bad), I would repeat the process - replace all the fluid in the master cylinder with fresh fluid and bleed the wheel cylinders again to flush the lines.
For the problem of a bouncy ride, it sounds like you need new struts.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
kikkup (11-08-2011)
Old 11-08-2011, 06:22 AM
It has air ride suspension,
Old 11-09-2011, 06:35 PM
Brian R.'s Avatar
Resident Chemist
I doubt it is meant to be a bouncy suspension. You better find out what needs to be replaced to stop the bouncing.
Old 11-11-2011, 07:53 PM
Thanks Brian, The suspension is controled by 4 actuaters , I was wondering if I had overlooked something, I finally got the water out of the system and the bouncing is still there, I ordered the actuators, $740.00 each, so I guess When they come in I will try that, I will keep you updated, with my progress, Thanks again for you're input..
hard start rjinmt F Series 1 01-07-2012 01:05 PM
honda passport shifts hard Drew_Navin Rodeo | Passport | MU 7 11-10-2011 12:20 PM
Tags
lexus , lx-470
