Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-07-2011, 03:17 PM
Drew_Navin Drew_Navin is offline
honda passport shifts hard
hi everybody, i have a 1999 honda passport with 113xxx miles on it, i bought it last night knowing it had this problem. i drove it around tell it was up to operating temp checked the fluid, it was the red it is suppose to be and didnt smell burnt at all. can anyone help me please, if you need more info i will try my best to.
thank you all in advance for the help.
Old 11-08-2011, 06:55 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: honda passport shifts hard
your transmission range position sensor probably nee to me cleaned;
http://www.walkerdowney.com/ryanendres//isuzu/#faq59
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-08-2011, 10:05 PM
you wouldnt happen to have a pic of it looks like would you? i found a shroud with 2 10mm bolts where the block meets the tranny i removed that but found no nut.
so i moved further back on the tranni and found a black plastic cover piece with a nut in the middle which is a 14mm i went wo losen it and the tranni sounded like it was going to pop out of gear. am i doing the right one?
Old 11-09-2011, 05:27 PM
Isuzu Guy
http://www.walkerdowney.com/ryanendres//isuzu/range.pdf
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-09-2011, 06:00 PM
Ryan, thank you so much that helped me out a bunch. going to do that tonight see if this is the problem, hope it is.
Old 11-09-2011, 06:01 PM
if that does not fix the problem, what else could be the problem?
Old 11-09-2011, 07:46 PM
Isuzu Guy
Sometimes Isuzu transmissions do funny things with a weak electrical system. I could be the battery, alt, or ground points.
Also, it is possible the tranny is dying. These tranny's like to have their fluid swapped out every 25-30k ... many people wait until 100k and then they have problems and the transmission is toast.
-Ryan
Isuzu Moderator
Car Show Tips
The Following User Says Thank You to amigo-2k For This Useful Post:
Drew_Navin (11-11-2011)
Old 11-10-2011, 12:20 PM
go under the the car last night removed the sensor cleaned it all up put it back on took it for a test drive and the shifting got much better but still rough, i did notice that the shifter was hard to pull back from Reverse to Low and Park was really touchy on getting it to go into park. im going to go back under tonight to click the gear shift forward one click and see if that hepls it.
2005 Honda Odyssey - Shifts Hard, Downshifts Hard rexolio Odyssey 5 08-14-2013 09:55 PM
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Overheating problems with 1994 Honda Passport batterton.nicholas Rodeo | Passport | MU 2 07-20-2011 12:05 AM
Please Help 95 Blazer shifting hard ryanusrey2012 Blazer 4 05-26-2011 09:53 AM
1998 Honda Passport Transmission Cooler lastrun Rodeo | Passport | MU 1 02-28-2011 07:10 PM
