Old 11-07-2011, 06:31 AM
parkerb parkerb is offline
fuel leak @ stainless lines??
hi all,
while underneath my '02, 150k miles, i noticed this mess behind the fuel filter. i've popped the bracket arm and wiped up a bit, but couldn't tell which of the 3 lines are leaking gas. anyone else had this happen?
Old 11-07-2011, 09:49 AM
mark_gober mark_gober is offline
Re: fuel leak @ stainless lines??
I've never seen anything like it and I've got 2 Windstars. There isn't any connection near where that bracket is, except for the fuel filter connections correct?
I'd probably spray it clean with a solvent like brake cleaner or something to remove the gasoline residue and then get back in there and check it again.
Those two black lines....those are brake lines correct? The reason that I ask is that brake fluid has an enormous creep. You can spill a drop and come back later and that drop will appear as though you spilt a gallon. It is possible that you have a brake fluid leak. In the photo, the black lines appear wet and the stainless dry. Is that the case?
Mark
Old 11-07-2011, 09:17 PM
mark, thanks for your thoughts. here's another shot showing a bit more of the run. you are correct, the filter is just above where the camera is. rub your fingers in it and it smells of fuel. but from around the car or up close to this there is no obvious sign besides the discoloration.
and yes, the black lines are the brakes. i'll likely pop a few more of the retainers off and free the lines to look around it. i'll report back because i'm wondering what the best way would be to fix this, especially if the part's obsolete?
Old 11-08-2011, 08:53 PM
wiswind wiswind is offline
Retainer on the line....rubbing/corrosion?
Fuel dripping from up at the filter or vapor canistor area and blowing back......and is dried up except for under/around the retainer?
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
liquid fuel leaking from exhaust manifold SoullessNihilist Blazer 9 11-15-2013 12:47 PM
Fuel leak in the engine compartment wolfkin_j Grand Prix 3 12-11-2009 07:25 PM
fuel leak where filter line meets tank line sonofthetonsured Cutlass Series 2 04-20-2008 12:56 PM
