Old 12-08-2009, 01:03 PM
wolfkin_j wolfkin_j is offline
Fuel leak in the engine compartment
I have a 2001 gp gt and for the past two days I noticed it began smelling like gas when the car was on. Checked under the hood today and found that there was there was a fuel leak where the fuel line connects to the fuel rail, the connection has upwards and downward play of about a centimeter and i'm no expert but that's probably the problem. I do not however know how to disconect it and was wondering if anyone that has had a similar problem in the past might know of it is a bad o ring or something or if the connection itself is to blame?
Old 12-08-2009, 06:07 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Fuel leak in the engine compartment
You can replace the o-rings inside the connector. You should use a fuel line disconnect tool. Try to get it fixed as soon as possible since the condition could cause an engine fire.
Timeslip 08/12/06
AF Community Guidelines
Old 12-11-2009, 04:28 PM
michtom michtom is offline
Do you have a procedure to replace the o rings and a source?
Old 12-11-2009, 07:25 PM
CrazyHorst CrazyHorst is offline
For a serious issue like this I would
a) not drive the car any more until the parts are replaced and the leak resolved
b) don't screw around trying to save a buck, I personally would just get the dealer parts no matter what the cost.
c) the fuel-line disconnect tool is available at any "chain" auto parts store.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Tags
fuel , grand , leak , prix , rail
