Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-07-2011, 12:52 AM
tahoedriver tahoedriver is offline
misfire and CES light
I have a 97' tahoe 5.7L 4x4 with 216,000 mi on it, this mourning it began to drive rough with the "CES" light flashing on and off. No problems before so I had AutoZone check the codes. I was told there was a misfire in cyclinder 7 and the O2 sensor on bank 1 before the cat was malfunctioning. The O2 sensors have never been changed. My question is do both O2 sensors before the cat converter need to be changed or can I do just the one? Also I'm gonna be doing a tune-up (plugs, cap n rotor, oil n filter, fuel filter), what else should I look for so the engine will run smooth again. I've checked vaccum hoses and pcv valve, all is good with them.
Old 11-07-2011, 10:19 AM
777stickman 777stickman is offline
Re: misfire and CES light
1st thing is to cure the misfire. Most o2 codes are generated by a poor running engine.
Also tell us what motor? In the future, we need code numbers (Pxxx).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-07-2011, 01:14 PM
The engine is a 5.7 L Vortec V8. How would you go about fixing the misfire. I checked the plugs from the other cyclinders and they look to have normal wear for a high mileage engine (scorched and dry with a light smell of burnt oil). Also I didn't ask for the code # from the guy at autozone and all he told me is what I've described in my post...rookie mistake I know.
Old 11-08-2011, 01:42 AM
quick update, I changed the plugs, cap n rotor, o2 sensor on left bank pre-cat, and the fuel filter. still idles smooth so no change there but upon giving it gas the engine doesn't shake as violently. Before when giving it gas the truck shook hard. How would I check the compression and the injectors...never done either before.
Old 11-08-2011, 01:44 AM
J-Mech J-Mech is offline
did you replace the wires?
2002 ABS and Brake lights coming on? Black_Blade Windstar 19 05-03-2011 11:59 AM
Tail and Backup Lights NOT Working ezmak Problem Diagnosis 1 10-08-2010 09:24 AM
'99 Yukon misfires and won't start ZippyCT Yukon 10 05-29-2009 08:46 PM
2004 LS - Misfiring and Engine Light On Tyree's LS LS | MKZ 2 12-13-2008 01:29 AM
99 Grand am SE v6 misfires and SES light stays on prettyd Grand AM 3 04-20-2005 08:50 PM
