Old 11-05-2011, 06:47 PM
Ted Atkinson Ted Atkinson is offline
1995 blazer
Have been working on my 1995 blazer for a week now have replaced o2 , crank sensors, fuel filter fuel regulator still stalls and surges after running for ten min. At a loss to whats the problem starts fine and runs great but it only takes til it warms up and runs bad and stalls, is it the spider hate to keep guessing .
Old 11-05-2011, 11:20 PM
FishFind FishFind is offline
One Hot Shot
Re: 1995 blazer
Yeah guessing is bad and the spider is alot of cash. I have head from some that it could by the ICM Ignition control Mod. NOT the coil its self. Also check your fuel pressures. Good place to start because you can rent and return the tool for full refund from autozone.
Old 11-06-2011, 01:58 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 blazer
Got any codes or check engine lights?
MT
Old 11-06-2011, 07:21 AM
Re: 1995 blazer
Have checked pressures all fine I bought the presurre gauge needed one any way I am a disel mech. No engine codes either, going to try map sensor, have suggestion from friends some think computur, but something is getting hot and shutting down it runs great cold soon has warmed up starts again, cools down then starts and runs great could it be distributors?
Old 11-06-2011, 10:21 AM
MT-2500's Avatar
AF - Advisor
Re: 1995 blazer
Have you cheked for lose of spark and or fuel pressure when or at the time it acts up?
What was the fuel pressure readings?
MT
Old 11-12-2011, 03:30 PM
Re: 1995 blazer
Thanks guys tried all suggestion finally broke down took it to a friend of mine and he put it on the machine and guess what after changing all the parts and sensors it was the damn computor it self bought a used one for 100.00 and the thing runs fine guess should have started out by going to tony and saved mayself some time and money, I am old school can fix anything but this damn electronic stuff. Going to but me a 1980s car and be done with it this almost made me want to buy a ford but good sense and good friends got me through.
Old 11-13-2011, 05:57 AM
MT-2500's Avatar
AF - Advisor
Re: 1995 blazer
You are welcome and thanks for posting back the fix and how it went.
Actually there is no machine that says bad computer.
But with proper testing you can check computer inputs and outputs and find out if computer is bad or good.
Good luck.
MT
1995 Jimmy misfires when cold reed92 Problem Diagnosis 11 01-17-2010 09:32 AM
1995 Blazer 4.3 laffer98 Blazer 7 11-30-2003 01:12 PM
1995 blazer brake hissing at pedal chefmikey Blazer 1 10-22-2003 10:52 AM
1995 Blazer service engine light on awbooth Blazer 10 10-16-2003 08:38 AM
How to check engine trouble codes on 1995 Blazer Schwa Blazer 3 07-14-2003 12:39 AM
