Old 10-08-2003, 04:35 PM
laffer98 laffer98 is offline
1995 Blazer 4.3
My stepson owns a 1995 Chevy Blazer that has developed a random missfire and the locale chevrolet mechanic say's the car is running rich. He suggest replacing multiport fuel injector and/or fuel line from same. The car has recently had new plugs and wires installed and a new IAC valve. Does anyone have any other ideas?
Old 10-10-2003, 05:27 PM
jaygaz jaygaz is offline
Send a message via AIM to jaygaz
95 blazer
i also have a 95 blazer w/ similar problems. A local mechanic said between the yr 95-98 chevy blazer,gmc jimmy's have a faulty central fuel injection sensor which allows the gas to flow around the cylinders. in my case it goes right though the exhaust system which has totally ruined my exhaust. it gives of white smoke and reakes like gas until it warms up. the only problem i dont have like $600 to fix it
Old 10-11-2003, 07:43 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 95 blazer
The 4.3 VIN # W engines prior to 96 did have a problem with the CPI unit or the lines feeding it leaking inside the intake causing had start,SES lights ,rough idle and black smoke complaints
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-21-2003, 05:14 PM
Re: Re: 95 blazer
This is different this is a white gas smelling smoke i have to get it on a computer i guess. thanks though
Old 10-22-2003, 05:13 AM
cobra1 cobra1 is offline
all this makes me glad my 95 S-10 w/CPI has made to to 176,000 so far on the original CPI unit.
to you other guys, ive seen where there is a fuel pressure reg. kit out now for about 50-60 bucks..... it is the reg that fails anyway, that or the feed/return lines. this substantially decreases the cost of this fix.
Old 11-26-2003, 02:40 PM
Ray Douglas Ray Douglas is offline
Send a message via AIM to Ray Douglas
Re: 1995 Blazer 4.3
My 95 blazer is doing the same thing,white smoke
not always stronge gas smell seams more so with
full tank. I'm loseing cooling fliuid not alot,air seams
to be getting into system? I did flush system maybe
have trapped air. can hear in cabin heater core. pressure tested cooling system for headgasket leak
seams ok. cad. converter radels maybe block outlet
condentsates their my smoke fog for 2 blockes help me please its driving me crazy!
Old 11-29-2003, 03:42 PM
engco463 engco463 is offline
95 running rich
Had the same problem..
simple test to determine if faulty fuel pressure regulator. connect a fuel pressure guage up to the test port while watching the gauge turn the key on, listen to the pump engage and watch the pressure when the pump turns off, if the pressure bleeds off then the regulator is bad..
bad thing is when chevy had the regulator on the external part of the engine it was about 15 dollars. but the 95 models placed it internally..
to a tune of $400
if you can afford the new one get it , but I found a salvage yard and had them crack open a shelved engine and paid 200 for the part.. it takes about 45 min to install.
another bad things was that most of the mechanics and dealers didn't have a clue.. said egr, o2 sensors everything but. good luck
Old 11-30-2003, 01:12 PM
sparky672 sparky672 is offline
Re: 95 running rich
Good test but only narrows it down to two items. If the fuel pulsator located in the tank is bad, you will ALSO see a pressure drop when the engine is shut off.
While fuel pump is running, crimp off rubber fuel line under car near driver's seat which isolates the tank/pump/pulsator. If pressure holds, then it's a bad pulsator/pump. If pressure still drops, then for sure it's the regulator/CPI.
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
1995 Blazer 4.3 motor knock joshschumacher Problem Diagnosis 1 07-29-2008 08:08 AM
1995 blazer 4.3, power seats problems waybrane Blazer 3 06-30-2004 06:10 PM
