Go Back   Automotive Forums Car Chat > Cars in General
Old 11-02-2011, 07:31 PM
davbell22602 davbell22602 is offline
Transmission ID Question
Are the transmission models stamped on all the transmission housings? Like th350, th400, 700r4, etc. If not how you tell by looking at it then without checking the casting numbers? So if your 2 hours away looking at trany to buy and seller refuses to try to look for those numbers for you. Then how you tell without making a 2nd trip back to get it if it is what your looking for on any car/truck brand transmission?
Old 11-03-2011, 05:49 AM
Re: Transmission ID Question
Originally Posted by oldblu65 View Post
Go to http://www.maliburacing.com/auto_tranny_id.htm for the info you need - Print it off and take it with you ! Good luck !
Where's ford, dodge, saturn etc. on that list. Bogus link.
Old 11-03-2011, 03:22 PM
All the transmissions you asked about were GM transmissions so I " assumed " that was all you were interested in ? Sorry I sent you a " BOGUS " Link ! Maybe you should have more clearly expressed what you were looking for and you wouldn't have had a " BOGUS " link sent to you !
I put it clearly in the last sentence on the first post.
Old 11-04-2011, 09:00 AM
Chris V's Avatar
Chris V Chris V is offline
The Big Meaney
yes, well, just because you only got part of your answer does't make it bogus. your response was just rude.
Take his list and add this for the mor popular RWD transmissions:
http://www.yearone.com/yodnn/TechFAQ...1/Default.aspx
For the rest, you're on your own. No one I know of makes a master list of all teh various automatic transmissions. if youre going to look at a FWD car transmission it behooves you to go and look at one in the car first to make sure what you are getting matches that.
I've owned over a hundred cars in the last 40 years. What was I thinking?
2013 MINI JCW Roadster
2023 Chevy Bolt
The Following User Says Thank You to Chris V For This Useful Post:
oldblu65 (11-04-2011)
Transmission Question....... 90CRXZCSi '71-'87 Civic | CRX 5 02-12-2002 02:29 AM
transmission questions SCMaxima2k Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 02-05-2002 08:43 AM
Transmission question Steel Engineering/ Technical 2 10-21-2001 01:56 PM
