Old 10-31-2011, 07:03 PM
scott_1553 scott_1553 is offline
Send a message via MSN to scott_1553 Send a message via Yahoo to scott_1553
01 Silverado - DEAD!!
Ok, I appoligize if this is a repeat question but I didn't see it in the first 100 or so pages.
I drove to work today with no issues. Because my truck and trailer were taking up half the parking lot, I went out to move it. When I got it......nothing!! When you turn the key, the radio, blower and accessories all turn on normally. When you turn it further it does nothing. The volt meter stays all the way down, gauges dont move and not even a sound. I charged the battery hoping it may be as simple as that. Nothing! I can jump the starter and it turns over just fine. (the starter was replaced two days ago..) I also moved the relays under the hood and I cannot even hear the fuel pump kick in. Any ideas??
Thanks!!!
Old 10-31-2011, 09:07 PM
j cAT j cAT is offline
Re: 01 Silverado - DEAD!!
Thanks!!!
so why was the starter replaced ? what was the problem with the other starter. did you clean all battery/starter connections and make sure they are tight,,,,including the starter nut that does not have a wire to it ?
Old 11-02-2011, 08:37 AM
Bob B Bob B is offline
If your battery has two cables on the red/plus side, like my truck, then you probably have to remove the bolt and clean both cables especially between them. I also had to replace the bolt to get it to tighten properly (NAPA or other auto parts store.
Bob B
2000 Silverado 5.3L 1500 4x4 Silverado_Dude Silverado 21 11-24-2009 10:02 PM
Dead pedal on cold start 2000 Silverado b_l_bailey Silverado 6 06-30-2006 09:00 AM
95 Silverado Tach, speedo, odometer dead lwin517 Silverado 1 01-31-2006 06:34 PM
Beating a dead horse, that isn't dead. Veyron Formula-One 2 02-04-2003 01:06 PM
