Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-26-2011, 07:43 PM
scotts96gt scotts96gt is offline
ABS problems
Anyone have any good ways to start trouble shooting the ABS system on a 99 century. I have a problem somewhere with the passenger side front sensor and or related wiring. Replaced the Hub/sensor assembly and the light went off for 5 mins but came back on. Not sure where to start and what to even look for. I am under the assumption i have a bad connection or broken or loose wires. There is also the possibility i have a bad sensor again as well but not sure how to do a down and dirty test on it. I dont have an ABS scanner and our local shop is a PITA to get in and have it scanned
Old 10-26-2011, 08:41 PM
Tech II Tech II is offline
Re: ABS problems
How did you know the LF circuit was the problem?
Let's assume you had a code for the LF wheel....Without a scan tool, it's just a guess....usually the sensor(part of the hub), or the wire harness to it....If you initially disconnected the harness from the sensor, and water came out of the connection, could have a water intrusion problem, which requires the hub/sensor AND the wire harness to be replaced....
What a tech would do, is put the car on a lift and look at data from the LF wheel with a scan tool, if he rotates the wheel, and gets no data, he disconnects the sensor and attaches the new hub to the harness...he rotates the hub, and if he now gets data , he knows it's the sensor....
If he gets no data still, 99% of the time it's the harness(very rare it's the EBCM)....a resistance check to the EBCM would verify it, but it's rarely needed to be done....
However, just one time, I ran into a case where a wire harness loom, rubbed against the A/C accumulator, and caused this problem.....there was a TSB out on this....caused various problems, depending on which wire/circuit was affected......FYI...
Old 10-28-2011, 05:46 AM
Re: ABS problems
The shop that had done some work to the car scanned it for me (which is also when the ABS light cane on) and said that the sensor was coming up bad. I already replaced the hub/sensor assembly, the light went off for a short period of time and now is back on.
Old 10-28-2011, 07:47 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: ABS problems
Sounds to me like the harness is broken down at the control arm. You can pull the wires out of the loom about 8" or so back from the connector to the sensor and inspect them. Most of the time the wire strands break inside the insulation and you cannot see it. The jumper harness runs about 75.00.
Old 02-23-2012, 08:26 PM
Re: ABS problems
Does anyone know what the part numbers are for the ABS connectors on a 99 century? both the car side and the speed sensor side? or better yet the part number for the jumper harness. All the searching i have done it seems like the low coolant sensor connector is the one that can be used on the car side but the bad connection i have is at the hub itself in the jumper connector
ABS problem, 2002 Ram 2500 4x4, 5.9 gas RedNeckerson Ram Pickup | Ram SRT10 3 09-17-2011 01:03 PM
95 Cavalier Master Cyl/ABS problems HebrewDude Cavalier Problem Diagnosis 1 08-02-2010 09:55 PM
2000 Ranger 4x4 trouble with ABS engaging tjohn2401 Ranger | Courier 1 01-15-2010 09:05 PM
95 Park Ave ABS problem / window problem tomdjones Park Avenue 4 08-31-2004 11:01 PM
ABS problems.....ABS and Traction off light came on at same time Jeff2392 Bonneville 4 06-10-2004 07:04 PM
