Old 08-02-2010, 04:46 PM
HebrewDude HebrewDude is offline
Question 95 Cavalier Master Cyl/ABS problems
I got a problem with this Master cyl/ABS assembly. The ABS has 2 bleeder screws on the end of it. The front one (straight) bleeds fine. The rear/side (angled) one has nothing coming out of it and zero pressure to my RF wheel. Changed the Master cyl/ABS assembly and the exact same thing is happenning. I'm thinking the assembly is fine, seeing as 2 did the exact same thing, so is it in my wiring, computer, module, etc? Anyone ever have a problem where a certain wheel is getting zero pressure? I was told it's a common and difficult problem... people have junked cars over it.
Old 08-02-2010, 10:55 PM
pappyl pappyl is offline
Re: 95 Cavalier Master Cyl/ABS problems
Sometimes the bleed screws get full of rust, etc.
Take the screw right out and blow it out with air.
Not sure if this helps
Tags
abs , cavalier , delco
