Old 10-25-2011, 09:34 PM
Wags391 Wags391 is offline
10-year Owner
Question Ignition timing jump when checking timing with light.
1992 S10 Blazer, 4.3L, 4x4, TBI (Z)
I was checking my timing with my timing light tonight, and I noticed that it has a little jump in it every couple of seconds. The timing mark would be dead on for a bit, then jump. I couldn't tell if it was jumping advanced or retarded, but it wouldn't not stay on TDC consistently for over 10 seconds. What could be causing this? I assume it has something to do with the ECM controlling the spark, but what would make it go off like that?
Thanks,
Jason
Old 10-26-2011, 04:12 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Ignition timing jump when checking timing with light.
Thanks,
Jason
Usually caused by not putting it in base time mode.
There is a brown and black wire that has to be unpluged to set base time.
Location under hood or at lower ac-heater housing depending on where the computer is located.
If not done the timing can not be set correct.
MT
Old 10-26-2011, 07:37 PM
10-year Owner
I did have it in base time mode. It was doing the jumping in base time mode. Is there something that could be causing this?? Distributor with module (reman) was put in this last July. Last time I tested the coil, it tested good. I don't know what else to check. I've even tried a different ECM. Would it be beneficial to try different injectors?? They are the original ones and have been rebuilt twice. The second time, along with the TBI and regulator, was a couple of weeks ago. I'm trying to figure all this out because I have a reman Jasper engine and I'm not getting any better fuel mileage than before. And the "miss" bothers the hell out of me.
Jason
Old 10-27-2011, 08:45 AM
MT-2500's Avatar
AF - Advisor
Jason
Check it out of base time mode also and see if timing is the same.
Also try another timing light.
Is the computer on fender apron or behind glove box.
Which way or what wire are you using are to place it in base time?
Did it set any codes after base time set?
MT
Old 10-27-2011, 08:54 AM
10-year Owner
The timing jumps in both modes. The ECM is up behind the glove box and the wire I disconnected is the brown (tan) and black one just below the dash (gives me a code when unplugging it). I know it's the correct wire. I do not have another timing light to use, unfortunately.
Old 10-27-2011, 09:53 AM
MT-2500's Avatar
AF - Advisor
Is the timing mark pointer the same in normal mode and base mode?
MT
Old 10-27-2011, 03:12 PM
MT-2500's Avatar
AF - Advisor
Also check it on the opsite firing cylinder and see if it jumps there.
MT
Old 10-27-2011, 06:53 PM
10-year Owner
In base time, the mark is timed at TDC. When in normal mode, the mark is advanced. What do you mean check the opposite cylinder? Cylinder 4?? If it does, what does that mean??
Old 10-28-2011, 03:13 AM
MT-2500's Avatar
AF - Advisor
Yes cylnder 4 is opposite firing cylnder.
And can be timed on no 4 the same as no 1 cyl.
Checking it on no 4 and if it does not jump would point to a firing problem on no 1.
Another thing that comes in mind could be a worn dist shaft bushing or gear.
Was the dist checked when motor installed.
Also dist cap and rotor.
Good Luck and let us know how it goes.
MT
Old 10-28-2011, 10:13 AM
10-year Owner
I will have to check the no. 4 cyl then. The full dist was replaced after the engine replacement, so the shaft and gear should be fine. If the no. 4 checks out okay, what would that mean for cyl 1? If it stills jumps on 4, what could that mean?
Old 10-28-2011, 12:10 PM
MT-2500's Avatar
AF - Advisor
Hard to say.
Go one step at a time and let us know what it does.
Also I would still try another timing light.
MT
Old 10-28-2011, 07:21 PM
10-year Owner
I just checked the number four cyl and it was doing the same thing. You can feel the engine missing also. So what can cause a sloppy firing when everything is just about new???
Old 10-29-2011, 04:09 AM
MT-2500's Avatar
AF - Advisor
CAN YOU FEEL MISS ON THE ROAD RUNNING?
Any check engine lights on or flashing?
Any codes past or present?
Good fuel pressure?
I would start checking fuel for good hot blue spaping/jumping spark from coil and into and out of dist.
ALL NEW PARTS usually winds up being a bad new part.
MT
Old 10-29-2011, 08:52 AM
10-year Owner
Can't feel any misses while driving. No codes, past or present. Fuel pressure is normal, around 12 lbs. What's a good way to test the spark? Just ground a wire? Spark tester? I agree about new parts being bad. I just wish there was a bad one to find. I can't find it!!
Old 10-29-2011, 11:52 AM
MT-2500's Avatar
AF - Advisor
They make spark testing testers with adjustable spark jump..
Or you can check with a metal insert like a screw driver in the end of plug wire and hold the side of it close to engine metal.
Spark should jump 1/2 in. and have a good blue color and a good loud snap.
Always check when cold and hot and after engne has run a 1/2 hr. or more.
MT
Problems with rear brake light and rear turn signal arfabe16 Neon | Plymouth Neon 0 03-08-2011 07:57 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
when checking timing oldchevy C/K 8 12-08-2006 08:39 AM
Timing Jumps in ESC Bypass Mode and Rough Idle when Warm 2000CAYukon Sierra 0 10-11-2006 12:42 PM
Tags
iginition , timing
