when checking timing
hey all,
on a 91 c1500 4.3L do I need to disconnect any vacume hoses or anything else when I check my timing? Or do i just do a straight hook up of +/- & #1 wire? I checked it today and it was totally wacked and way off of 0. It's running well, but I just happened to check. thanks |
Re: when checking timing
Then set base time and the hook wire back up and clear code and go. And before you ask it is a single tan and black wire with a plug in connector on it. Under heater core housing /or behind/under glove box in cab When it is unplugged it will set code and turn on check engine light. So clear codes / battery neg cable off and on will do it when done setting time Also sometimes the EST wire is laying under carpet at/under heater core housing. MT
Just curious if this is unique to the 4.3. //2000CAYukon |
If light gos out the no problem. But sometimes it still helps let the pcm reset after tune up or adjustments.. MT
//2000CAYukon |
thanks MT.
found the connector inside the enginie compartment. Even though i can check it, there is nothing I can really do to adjust the timing is there? the 91's were not adjustable. I guess the only reason to know my timing is for time like when replacing the dist. shafts or chains i would think. Is there anything I can do to adjust or fine tune the timing or will anything I do be adjusted back by the ECM? I've never needed to check it in the past, I just happened to come across a brand new timing gun at the pawn shop the other day for only $4.95, so I thought i should pick it up..but it's not my old firebird.
Old Chevy -1991, C1500 V6 4.3L 2WD Automatic, No a/c 220,000 Miles. |
//2000CAYukon |
thanks yukon.
I thought that was the way, but i thought that the ECM then tries to adjust it back. I read where you said your manual covers all engines for 1990, does that cover the 91 4.3 as well. I don't think there was a change from 90-91
It sets the pcm in base time so you can addjust it. Was it a single tan/black wire that you unplugged? Where was it in engine compartment?
