Old 10-23-2011, 12:00 AM
lvangundy lvangundy is offline
Send a message via AIM to lvangundy
Moilten metal on 3rd O2 sensor
I replaced my 3rd sensor found this. We thought it was lead so we heated it up but it didn't melt - is it platinum? Or melted stuff from inside the cat? WTF?
Old 10-23-2011, 08:34 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Moilten metal on 3rd O2 sensor
Wow, that's interesting! Is the "clean" metal of the sensor around this from where you tried to heat it up, or did it come out of the car that way? As smooth as that metal looks it must have been really hot when it hit the O2 sensor. Was any exhaust welding done near that sensor?
-Rod
Old 10-23-2011, 12:52 PM
Good guess - there was welding done for a wideband O2 sensor but it was in front of the first cat, seems hard to imagine it traveled so far. You're probably right though.
Old 10-23-2011, 09:21 PM
shorod's Avatar
SHO No Mo
It does seem hard to imagine that weld would make it through the converter and still be hot enough to bond to the sensor.
-Rod
Old 10-24-2011, 10:32 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
That's the cat's ceramic internals melted and blown onto the downstream sensor. It'll look metallic from the platinum catalyst. Time to replace the cat and check/replace the upstream ones...they're letting the engine run rich.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Metal to Metal sound when turning? Civix '88 - '91 Civic | CRX | Wagon | Shuttlee 17 04-19-2005 08:09 PM
a metal on metal grind near tranny daedalus Off-Topic 6 02-27-2004 04:09 PM
