Old 03-24-2005, 09:26 PM
Civix's Avatar
Civix Civix is offline
Metal to Metal sound when turning?
Whenever I back up with the wheel turned right or left, I hear a squealing sound. Almost like metal to metal sound. It kinda comes and goes why backing up. I looked over the cv joints but they're just in find condition. What could it be?
With my Civic, I'm Pimping Yo
Old 03-24-2005, 09:32 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Metal to Metal sound when turning?
does yoru car have power steering ?
Team Lonely Drivers
Old 03-24-2005, 09:36 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
yeah my car too, when i turn its like a metal squeak, dont know tho. i think its coming from the steering wheel shaft.
Old 03-24-2005, 10:41 PM
i had something like that on my other car and it turned out there was no powersteering fluid
Team Lonely Drivers
Old 03-24-2005, 10:58 PM
no my car dosnt have ps.
Old 03-24-2005, 11:02 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Check your dust shields. I had the same sound. Turns out my dust shields were rubbing against my rotors.... no idea how it happened but it fixed my problem.
Old 03-25-2005, 11:05 AM
Civix's Avatar
Yeah, i don't ps either. So what did you do to the dust shields to make it stop?
Old 03-25-2005, 12:08 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
is it a squeak or a clunk? cuz i know if its a clunk then its some worn joints in the steering asssembly. but if its a squeak then i dunno. maybe something needs to be lubricated or something. if i was in that position i would just take apart the sttereing assembly and try and figure it out. but then again i have two rides soo...
gimme some time. ill think of something witty and clever to put here.
Old 03-25-2005, 12:33 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
hmm my car did it also. no ps, but it did sound like the steering rack or some thing. ill have to get it back on the road to see if it still dose it(when i parked it ,it wasnt doing it)
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-26-2005, 01:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
jack you cars up, and look for any signs of rubbing in the wheel wells, you know maybe one of the tires is rubbing on the splash guards around the engine bay (my car does that with my winter tires on. You'll find something if you look hard enough, whether its tires rubbing, suspension, axles...
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-26-2005, 02:32 PM
Its Kinda Like When I Turn It Squeaks Not The Tires But The Steering Rack,,and Only In The Morning.
Old 03-26-2005, 10:13 PM
Re: Re: Metal to Metal sound when turning?
Ohhhh alright. so it squeeks as your turning the wheel? I thought you meant that it was makin noise with the wheel held around a turn or somethin. Try to listen if its coming from the strut bearings. thats right under the hood basically right at the top of the strut tower. Or if its coming from under the car where the rack is at. hopefully its not the rack because thats no fun to replace oh yea also, where do you live? if its cold where you are and since it only happens in the morning, maybe a bushing?
ZC stuff
Old 04-15-2005, 10:21 PM
Civix's Avatar
Well I looked at the front drivers side wheel since that's where the noise is coming from. I couldn't fine any sign of the dust shield rubbing or even the rotor being loose. The tire is also not rubbing up against the body. But now since summer is coming and things are warming up, I'm finding the squeaking coming alot more but now it's not just the turning. it'll do it when I'm in a straight line. Also the squeaking only happens when I reverse. WTF is going on here? Seriously?
Old 04-16-2005, 07:47 PM
BullShifter's Avatar
check the brake pads.
Old 04-18-2005, 04:29 PM
Civix's Avatar
Why the hell would it be my brake pads? Wouldn't I hear it then if i was going forward?
