Go Back   Automotive Forums Car Chat > Saturn > Aura
Old 10-22-2011, 01:11 PM
Sponfry Sponfry is offline
Cool Oil leak above filter housing
Anybody seen or know about oil leak from above oil filter housing. 2007 Saturn Aura 3.5. I cleaned filter and all around housing, start engine, and oil right away starts leaking. But coming down from above filter housing. Took side covers off, but can't see where it is coming from.
Old 01-09-2012, 11:02 AM
dbinck dbinck is offline
Re: Oil leak above filter housing
Sponfry - Did you ever figure out the oil leak? I'm having the same issue.
Old 01-09-2012, 12:15 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
The oil pressure sensor sits above the oil filter housing, thats probably whats leaking.
Old 01-09-2012, 01:29 PM
Thank you very much for the information!! I will take a look.
Old 01-09-2012, 01:32 PM
Yes I found the problem.... It was the gasket between the filter housing and the engine block. Was pretty easy to change.
99 Burban Oil leak at Oil filter housing?? OZBIRN454 Suburban 1 07-31-2008 04:35 PM
95 LeSabre Oil leak on pass side above oil filter... AJsOffroad LeSabre 2 06-02-2008 06:48 AM
metro with oil in air filter housing. ahaus Metro 2 05-14-2008 02:35 AM
1.6 Diesel Golf/Jetta 92 Check oil pressure from filter housing,checks 85 PSI!!!! D Ram '91 - '96 4 03-23-2005 05:27 PM
Oil leak at filter ZipLock Malibu 1 09-24-2004 10:47 AM
