Old 10-22-2011, 01:07 AM
Sayshell Sayshell is offline
Car leaking fluid what is it?
Hey I have 2004 Ford focus hatchback ZX5 and its leaking a fluid near the driver side by the engine. The fluid is clearish and odorless and it only leaks when the car is driving. It is directly below the battery and windshield fluid input. The battery appears to be wet. Any ideas what it is or how to test it?
Old 10-22-2011, 07:52 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Car leaking fluid what is it?
Welcome to the forum!
Does the fluid evaporate over time, or does the puddle remain on the ground unless you clean it up? Have you checked the fluid levels of things like the power steering pump and the brake master cylinder? Does your car have a manual transmission with hydraulic clutch, and if so, check the level of the fluid in the clutch master cylinder. Is there any corrosion taking place where the fluid has been running down the engine compartment?
-Rod
Old 10-22-2011, 12:42 PM
The puddle evaporates over a couple minutes. I am 100% sure its not gasoline, I think its antifreeze because it has little to no odur, leaves no stain, and feels like water with a bit of an oily texture. Its not the brake it is definitely leaking from near the top of the engine. Their is no corrosion, and its not from the transmission as its not near that area.
Old 10-22-2011, 01:54 PM
inafogg inafogg is offline
can't think of anthing that would be leaking & evaporating in minutes
unless its ac draining & its a hot day
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-22-2011, 02:27 PM
I took it to canadian tire and the mechanic says its washer fluid. So I guess I wont bother fixing it, cause its not too much that is leaking and its probably cheaper just to refill it every so oftan.
Old 10-24-2011, 10:35 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Could also be power steering fluid. It is a very light oil that evaporates/absorbs into concrete fairly fast.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 08:51 PM
Transfer Case Fluid.........What Is It? bigbleu515 Problem Diagnosis 3 02-14-2008 04:29 PM
Car engine not what it used to be... Vipey1337 Grand AM 3 09-05-2006 01:20 PM
Brake fluid???WHAT THE HELL IS IT toyota michael Car Modeling 10 06-10-2004 05:49 PM
leak but don't know what it is cardz Intrepid 1 01-11-2004 09:26 AM
