Old 10-21-2011, 01:03 PM
comet240 comet240 is offline
97 cav theft mode on cant get it off
hi i have a 97 cav i done the 3 key time trick turn key on leave for 10 min off pull key out for 5 seconds in again for 10 on etc doesnt work, bought the 200 dollar bypass pro module that bypass's the theft system but doesnt work,
used to be able to turn key three times and it would flash codes but all it does now is stays on solid the engine service light,
is this a problem of the ignition switch? as it had a recall on the igintion switch if u start too long it burns out but it was replaced in past and gm doesnt honour 2nd time they say its not faulty
so would it still be the igition switch? and how hard is it to replace? and do u need a new key or is it good enough? as i think the wire that has the resistor or something is not working telling car its ok
Old 10-21-2011, 01:53 PM
jdl jdl is offline
Re: 97 cav theft mode on cant get it off
If you paid 200 dollars for a bypass module, I'd talk to the manufacturer and get my money back. With GM OBD2 you never could get flash codes, that won't work. Use an obd2 coder. No offense intended, but, you don't act like, you know what your doing?
Old 10-21-2011, 02:06 PM
sure i know what i doing
all i know is an igition switch is different from an igition cylinder and the switch has the resistor for the theft system for the pass lock 1 code
and for the 97 i used to be able to turn key 3 times to get security codes but now engine light just stays on
and as the 3 times for 10 min thats to reset the pass lock 1 system i did what gm said to do and didnt fix it
and the pro bypass company that bypass's the anti system of all cars said it is not there module and problem is bigger
they figured its the cars computer i thinking its the resister in the igntion switch and the ignition switch is 150 bucks
and i was not sure if the obd code reader ifi buy it will tell me if the igntion switch is burned out or if the computer is burned out,
all started cuz the cataylic converter was turning red hot then it wouldnt start anymore and cranking too long the starter stuck the car into theft mode and a 97 cav and up and sunfires are all known for there faulty igition switch that sends high current and can start fire etc, so i figured maybe the wire from igition switch that tells the theft system then to the computer is burned out
Old 10-21-2011, 06:37 PM
Tech II Tech II is offline
Think you have some misinformation....
Maybe your THEFT light was flashing, but those weren't codes....
The resistor or R-Code is in the PassLock module, not the ignition switch.....
Was the cat ever replaced? Fix the problem that caused the cat to overheat?
all started cuz the cataylic converter was turning red hot then it wouldnt start anymore and cranking too long the starter stuck the car into theft mode and a 97 cav and up and sunfires are all known for there faulty igition switch that sends high current and can start fire etc, so i figured maybe the wire from igition switch that tells the theft system then to the computer is burned out Today 02:53 PMall started cuz the cataylic converter was turning red hot then it wouldnt start anymore and cranking too long the starter stuck the car into theft mode and a 97 cav and up and sunfires are all known for there faulty igition switch that sends high current and can start fire etc, so i figured maybe the wire from igition switch that tells the theft system then to the computer is burned out Today 02:53 PM
Does the car crank over? Have you checked your starter? You can try to reset the PassLock system until the cows come home, but if your starter is bad, the car will not crank...
You need a code reader to read codes....but even most codes readers don't read "B" codes....code readers /scanners don't diagnose bad ignition switches...techs do.....
Old 10-21-2011, 11:02 PM
they 3 times that takes 30 min was to reset the passlock and the theft light never flashed ever or shut off always stayed on
as for the codes it used to display like code 66 and the service light would flash to give me the codes but now the service light stays solid
so where is the pass lock module located can u buy that seperate and can a regular obd code reader tell me if thats burned out at all?
all this happened after i replaced the cat i put whole new exhaust on front to back as the old one was busted so it turned red hot i had cat replcated twice and then car shut down and i started and started and started then noticed theft system on, the garage said it probably be the rad sensor thinking the car engine too cold pumping more fuel into the engine so i replaced the tempeature sensor but dunno if it fixes it as the theft system never shuts off
car cranks over and u can turn key on and here the pump trying to prime but never does
do the laptop code readers work the one with the enhanced features? ya GM says they can diagnose it cost 150 bucks for them to check it
what are B codes?
Old 10-22-2011, 08:11 AM
Well, as for the Theft light, sometimes it flashes and sometimes it just stays on solid, during the reset process....but it DOES NOT FLASH CODES....
"B" codes are body codes......With the PassLock system, the usual codes are B2958 or B2960......
The service engine light NEVER flashes codes on an OBD II vehicle.....the only time the SE light flashes, is when there is a misfire happening, to alert you that this could damage the catalytic converter....
Old 10-22-2011, 09:13 AM
ah ok ya never seen theft even go off ever
but like i stated couple times now i got the codes off the CHECK ENGINE light the service light not the theft as i was told this car is capable of doing key on of 3 times right away to get codes like in the past it was only nice feature it had
cuz in all 96 cars u can do the key thing but ok
so would the scanners that plug into your usb with the enhanced code readers tell me the fault?
but ok thanks for input if i cant find it guess i gotta push the car to a gm dealer lol
Old 10-22-2011, 02:53 PM
Well, there is NO FLASH CODE capability on these cars....
It's funny, there a re a lot of customers out there that think we just plug in our GM scan tools, and the tool tells us what is wrong with the vehicle.....that is so far from the truth, it's not funny.....
Scan tools just give us information....it may give us a code, but it doesn't mean the problem is what the code is named after....for example, you get an O2 sensor code, so the average person runs out and gets an O2 sensor and installs it...yet the same code comes back.....all that code means is, anything that is in the O2 sensor circuit(sensor, wiring, PCM, ground, etc.) or anything that affects the output of the sensor(exhaust leak, vac leak, fuel leak, misfire, etc.), can cause this code......
So a code reader or even a scan tool, won't tell you what is wrong with your car.....you have to be able to determine that, by interpreting data, and following diagnostic trees....
Since your vehicle cranks, your next move is to check for spark, fuel pressure(with a gage), injector pulse, and compression....
Old 10-22-2011, 08:43 PM
ah ok all i know is i guess they said cuz the car was made in certain year of 1996 that it was able to do codes by key
but for the car
it does crank, it does spark, and it does get fuel, it has compression. and the injector pulse i dont know how to check that but it does not get fuel pressure as i was told the theft system on this car does no allow it to pressure up or how ever that works
as u hear the car priming each time u turn key
now i did get told today but i forgot there is a purple security wire if u bypass that wire or twist it to the fuel pump wire it will run they did it to a sunfire but i have to re ask
and what is the fuel pressure supposed to be there is no port on it to allow me to check with gauge though
Old 10-23-2011, 10:23 AM
If the PassLock is not giving a signal to the cluster the cluster won't send a fuel enable signal to the PCM......the fuel pump is not affected by this system....it should build pressure......but if there is no signal, then the PCM will not fire the injectors.....
Which engine is this? A 3.1/3.4 has a schraeder valve by the P/S unit....the four cylinder quad engine, if it doesn't have one on the fuel rail, doesn't have one....need a special setup to insert in the fuel lines, to get pressure....
Have your tried spraying carb cleaner into the throttle body to see if it will start and run? Spray into the throttle body and let it sit a few seconds.....then have someone crank the vehicle as you spray.....if it starts and runs or almost starts and runs, you have a fuel delivery problem....either the pump is not creating enough pressure(just because you hear it run doesn't mean it's building pressure) or the injectors aren't firing......
Old 11-03-2011, 07:04 PM
hi sorry for delay been away
when i turn the key on u hear the pump run and then shut off u can turn key off and back on keep hearing it run but never pressureizes
the engine is the 2.2
and ya dont see no fuel regular
like the theft light never goes off now i have where i kept cranking and after abount a minute or so of cranking not constant cranking it will fire for a second then shut down
does the PCM or say pass lock affect the engine from pressurizing though?
so what setup do i need to add a pressure gauge to it or what not?
Old 11-03-2011, 08:23 PM
Did you spray carb cleaner into the intake to see if the car starts? Does it continue to run as loing as you have someone spray? If yes, it's fuel delivery.......either no pressure or the injectors are not firing....
If there is no schraeder valve, usually on the fuel rail, You need a special setup for a fuel gage.....follow the fuel inlet(not return) line back from the fuel rail......you will find a metallic connection that can be seperated with a special tool......the setup you need has to have the same male and female couplings as the fuel line and it has to have a port in the middle to attach a gage(GM shops have this setup)......
You can't tell what fuel pressure is, just because you hear the pump when the key is turned on.....
If you had a fuel injector light, known as a noid light, you disconnect one injector harness and attach it.....when you crank the vehicle, it should flash....if it flashes once or not at all, chances are it's the Passlock system not allowing the injectors to fire.....The PassLock system doesn't prevent the pump from building pressure......it prevents the injectors from firing.....
Old 11-03-2011, 08:33 PM
hi no never got chance to try carb cleaner as i read this meassage and its already dark ill try tommorow
can i use a 12 volt algtor probe the prob with a light bulb in it?
and if it doesnt light and you say its the pass lock what part of the pass lock needs to be fixed?
ill try tommorow the carb cleaner
Old 11-04-2011, 10:08 AM
You can use a test light, as long as the the DC bulb is at least 12 ohms, on the injector harness.....don't go to a ground...you have to attach it to both connectors in the harness.....careful you don't short them out together, could lose the PCM.....
As for what the problem is, if the bulb doesn't flash? Hard to say.....could be the PassLock sensor......could be a wiring problem......on your year, I think your vehicle used the "smart cluster" rather than a BCM.....if that's the problem, then the cluster woud have to be replaced.....
This circuit is pretty involved......without being able to read codes in the vehicle, you are really guessing.....but if the vehicle starts and runs with carb cleaner in the intake, you have a fuel delivery problem......you can't check fuel pressure without the setup I mentioned.....if the injector light doesn't flash, then it's either the PassLock system(guessing since you have had problems with it), injector fuse is blown(with the key on, use your test light to ground and check for power on one of the legs, it's usually the common color to all four injector harnesses) OR you may have a PCM problem(could be the PCM......or wiring....or a sensor or module, for example, maybe the ICM is not sending a reference signal to PCM to fire the injectors).....
This is why working on vehicles today, is so labor intensive sometimes.....you have to have a starting point......then you eliminate potential problems by following a trouble tree.....a lot of techs try to skip this process, and thus don't "diagnose" the situation correctly....this ends up being a lot of needless parts being installed.....this is basically where you are.....but you are not alone......when I am at work, I have all these tools at my disposal.....I can bring my own vehicle into the garge before or after work and use them.....but if I tried to diagnose it at home without the tools and information available at work, I'm lost....then I am in the same boat that you are in...
Old 11-04-2011, 03:59 PM
hi
so i dont have someone to test with yet later today but i did try on my own with the carb cleaner and the engine fires up for the second and shuts down cuz i cant spray and start lol and the engine line goes out for that but still left with theft mode on
so i take it thats agood sign? also i did try a fuel regulator off of the 98 sunfire i have and that did not help it so i cant test the light theory and i have no idea if its a 12 ohm or not
so in all and all if i buy those 250 dollar obd 2 code reader will it help me? will it tell me any codes or does ti have to be a tech 2 scan tool from gm? i was thinkiing getting the pc version from
drew technogolys the Mongoose or the auto enginuity i looked at for home base there was another one i download the software i forget if that was the mongoose u download your car type and it gives u the specs min and max of each sensor too and what it currently reads too
ya i liked older cars less sensors now more sensors more headaches lol total BS lol i bet it gets worse later on lol
97 Theft System light on and i cant get off comet240 Cavalier Problem Diagnosis 2 07-06-2011 07:18 AM
1969 power steering cant get off jerry jacks Continental 1 12-02-2008 08:24 PM
Cant get the heat shield off...... Mustang83 Mustang Talk 1 08-08-2004 09:16 PM
99 Suburban K2500 I CANT Get Front Rotor Off!!! Ace Greenberg C/K 4 05-03-2004 03:45 PM
Cant get the ciggarett plug off my dash help please Harryc8786 Malibu 3 12-14-2003 04:40 PM
