Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-19-2011, 07:13 PM
95astroman 95astroman is offline
Smile 2004 Corolla front wheel bearings
Hi all, I'm hearing a wheel bearing "whine" now after 125K on my salvaged Corolla. How do I replace the front wheel bearings on a 2004 1.8L Corolla. Any special tools required. The sealed bearing cost $40-$60 each.
Any help appreciated :-)
Old 10-24-2011, 10:58 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2004 Corolla front wheel bearings
Those are pressed in to the hub, so you'd be best to remove the hub assembly and have the new bearings replaced at a shop with a press.
The CV shafts have a retaining nut that is staked instead of having a cotter pin, so you'll have to bend or remove that part to be able to unscrew it from the shaft end. You'll also need to buy two new nuts from Toyota and a 30mm 12-point socket.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-13-2011, 12:59 PM
Nate Jacoby Nate Jacoby is offline
I just finished replacing the wheel bearings on my car. I had never done it before but it was fairly easy. I looked for awhile online for a great set of instructions and these were the best I could find. I hope they help and there were a few tools that I needed to borrow from a friend of mine.
http://connect.timken.com/removing-a...aring-assembly
The Following 2 Users Say Thank You to Nate Jacoby For This Useful Post:
Brian R. (12-13-2011), salesmantony (12-14-2011)
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
Front Wheel bearing Front Assembly - 2000 Alero penguinforum Alero 3 10-17-2009 09:24 AM
2004 Impala Front Hub Bearing Mountain Top Impala | Impala SS 3 11-04-2006 06:14 AM
2004 Suburban front differential bearing paulfischer Suburban 1 03-09-2005 09:31 PM
WTB: 2003-2004 Corolla front bumper winner007 Corolla/Matrix/Voltz 1 05-22-2004 12:29 PM
