Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-02-2006, 02:29 AM
Mountain Top Mountain Top is offline
2004 Impala Front Hub Bearing
Can the bearing in the front wheel hub be replaced whth out changing the hub or causing damage to it. I have a press here that can be used if necessary.
Old 11-02-2006, 06:14 AM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
Re: 2004 Impala Front Hub Bearing
No, the hub and bearing assembly is a sealed unit and is not repairable.
Old 11-03-2006, 09:56 PM
16th hippy 16th hippy is offline
not to mention is alot easier to replace whole thing...especially with ABS
Old 11-04-2006, 06:14 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Welcome to AF Mountain Top.
A hub bearing change is a DIY job with the right tools (hub puller, axle nut socket, torque wrench, etc...). If you have the mechanical ability to do your own brakes, you can do a hub. The most important things to remember are:
1. Don't buy the cheapo, whitebox Chinese A-Z brand hubs, you get what you pay for.
2. Don't even look at an air impact wrench. The hammering action will damage the hub and it's wheel speed sensor, leading to premature failure.
3. Follow the repair manuals instructions, including cleaning the rust/dirt off the hub mounting surface and using a torque wrench to tighten the bolts and axle nut (this is the MOST important step) as axle nut torque pre-loads the hub and failure to do so will cause the hub to growl and fail.
If the new hub contains a torque spec in the box that differs from your repair manual, use the torque spec with the new hub. Changes in hub design sometimes necessitates a change in the torque spec, so don't use the repair manual spec if the hub says differently. Good Luck.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
