Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 10-17-2011, 04:34 PM
hungarian_boss hungarian_boss is offline
Send a message via AIM to hungarian_boss
2005 Ford 500 shakes when braking
My Ford 500 has been starting to shake when braking.
At first I thought it was the front pads and rotors, so I replaced the entire front w/new pads, and rotors.
Didn't fix the problem.
Then, just this wkend I changed my rear pads. I checked the runout for both back rotors, and they were both within .005" so I know for a fact, they aren't warped. I knocked any rust off the perimeter.
All calipers are working fine (front and back), as far as I can tell.
Steering wheel shakes alittle, not much. The shaking is much more noticeable through out the car as opposed to the steering wheel. And i'm not feeling a pulse through the brake pedal.
I'm stumped. I've tried everything I can think off. I just wanted to get some other opinions before I take it to a garage and pay just to be told whats wrong.
Old 11-18-2011, 08:28 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 2005 Ford 500 shakes when braking
Generally a problem ( on the front of your car ) will be felt in the steering wheel as it shakes , vibrates , etc. so I suspect your problem is at the rear of your car . Have you had your tires checked ( balance as well as a possible slipped belt inside the tire ) ? Might have a bent wheel , a loose u - joint , loose shock , just a multitude of possibilities . Check all the bolts and nuts under the car and make sure all are tight and you haven't had something come loose and fall off . It is frustrating , I know ! Good luck !
" Sometimes I grow so tired "
2005 Ford 500 Hesitates and down shifting problems bmkj02 Five Hundred 3 08-11-2009 03:37 PM
02 Silverado shakes when braking. kegster Silverado 17 07-17-2009 07:57 AM
Brake pedal shakes when braking at or above 50 mph? mrtwo Camry/Camry Hybrid/Vista 4 07-03-2005 10:07 PM
shakes when braking tacotrain Neon | Plymouth Neon 3 03-31-2005 05:41 AM
F 150 Shakes When Braking ajga F Series 2 07-01-2004 12:31 PM
