Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-26-2005, 03:41 PM
mrtwo mrtwo is offline
Brake pedal shakes when braking at or above 50 mph?
I 've noticed this problem for quite a while. The brake pedal shakes (vibrates) when braking at or above 50 mph. It happens every time i go down a long slope or on highway. The streering wheel shakes a little bit too. It does not happen below 40 mph. I change the brake pads (front) this march and it did not fix the problem. So what can be the problem? Thanks.
Old 06-26-2005, 09:41 PM
hueroloco hueroloco is offline
your brake rotor runout is excessive. basically they're warped.
Old 06-27-2005, 08:41 AM
Re: Brake pedal shakes when braking at or above 50 mph?
Then what work needs to be done? Replace the rotors or resurface them? Thanks.
Old 06-27-2005, 01:24 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Re: Brake pedal shakes when braking at or above 50 mph?
You are correct; resurface them if there is enough meat left on them (wherever you take them to be cut will check the thickness first) or replace them with new ones. If there is plenty of pad left, just sand them lightly so they will seat better to the new rotor surface.
Mike
Old 07-03-2005, 10:07 PM
jtoyotaman jtoyotaman is offline
most places dont turn rotors anymore go ahead and buy new ones, and replace pads again, dont buy pads that have lifetime warranties because they are made so hard they will actually wear your rotors out before the pad itself.
