Old 06-23-2004, 02:52 PM
ajga ajga is offline
F 150 Shakes When Braking
Is My Truck Shaking Because My Rotor Is Warpped?
Old 06-27-2004, 06:38 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: F 150 Shakes When Braking
Most likly. A warped rotor is from riding the brakes, might want to change your driving habit a little bit. I would go through the front brakes, new rotors and pads and rubbers lines if they are bad. I would say bad rotors from your discription.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 07-01-2004, 12:31 PM
ervinj ervinj is offline
Warpped rotors can be caused from a lot of things, A bad soft brake line could expand causing the caliper to open and close at the wrong time. New pads that are too thick can cause overheating thereby causing the fluid to expand or, just bad clipers could cause it. Have the rotors been turned several times? I've read were it's recommended to have the rotors faced each time you change pads. If they've not been turned too many times, have it done. If the front end pulls to one side when you break, check the soft lines.
Hope this helps.
ervinj
