Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-16-2011, 04:18 PM
budscuz budscuz is offline
confusing tranny problem
'96 Bonny, normally aspirated. No codes.
Took it out for a Sunday drive, this is what I get...
At 45 mph, holding the throttle steady, I lightly applied the brake. RPM skipped up maybe by 200. After releasing brake tension, the RPM dropped by about 200. I'm thinking "the tcc is working again!" On the highway, at 65 mph, the tach shows me about 3000 RPM. I lightly applied the brake, RPM skipped up by about 200...
then down 200 after brake release. After performing this experiment several times, I confirm that the tcc is engaging, but not overdrive.
Several runs up and down the hiway under different acceleration and inclines, I've determined it is not going into overdrive. However...it may be trying to get overdrive when I "wiggle" the column mounted shift lever from 4th into 3rd. After all my investigation I have to start over. Do you guys have any ideas to what is happening here? Thanks, Ken
Old 10-16-2011, 06:59 PM
Tech II Tech II is offline
Re: confusing tranny problem
Does sound like the TCC is engaging, but you don't have fourth gear.....
Start car in "3" instead of "D"....get it up to 65......are rpms at 3K(make sure the car is at normal operating temp).?.....now shift into "D".....if no change in rpm's, no fourth gear....
Old 10-16-2011, 07:44 PM
Confirmed...Changing gears, 3 to 4 and back...No 4th gear. Is this something Sea Foam can fix, or is this a job for superman? lol
Old 10-17-2011, 07:44 AM
maxwedge maxwedge is offline
A990 racer
More than likely the trans will have to come out as the o/d clutch hub has failed, common problem on these trans.
Old 10-17-2011, 11:48 AM
Yeah... I hate automatics. Fixing this thing is gonna cost more than the car is worth. Reckon I'll have to figure something out. Thanks for the feedback, guys.
Old 10-19-2011, 08:12 PM
Jrs3800 Jrs3800 is offline
Its not really common of the 4T60E to kill off the 4th Hub splines... It is possible for the clutches to be shot for overdrive...
I would at the least have a trans shop or a good shop scan the car to see if anything is off kilter before you doom the trans...
99 Pontiac Montana Tranny problems? wilson8260 Montana/Montana SV6 9 12-22-2009 09:16 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 03:41 PM
Very confusing electrical problem Dirty hans 5 Series 3 06-04-2005 05:53 PM
confusing electrical problem...at least thats what it acts like! nute4260 Cutlass Series 7 10-13-2004 12:28 AM
