Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-15-2011, 07:52 AM
4Runner03's Avatar
4Runner03 4Runner03 is offline
Send a message via AIM to 4Runner03
2003 4runner brake warning light glows dimly.
I have a 2003 V8 4WD SR5. It has 109K miles and I replaced the pads and rotors and front calipers about 8-10K ago. Since then it has been doing fine in the brake department.
This morning, the brake warning light (the parking brake light) came on about half illuminated. The parking brake is not on and when I press the parking brake it illuminates fully. The other warning lights associated with the brake system (VSC TRAC OFF, VSC OFF, and ABS) are not illuminated. The fluid is at the max line, if not a bit above.
Given this info, I don't believe there is a major problem or else it would actually be fully illuminated and the other lights would be on as a result of the brake light. I am just curious what is causing this issue and how to fix it. Thanks.
2003 Toyota 4Runner V8 4WD
1999 Honda Accord EX 4CYL
God Bless!!!
Old 11-10-2011, 02:25 PM
Dunerider600 Dunerider600 is offline
Re: 2003 4runner brake warning light glows dimly.
4runnner03,
i get this very problem with my 01' Tacoma. i solved it by adjusting the parking brake, and also sometimes the park brake on/off switch goes bad.
Old 11-13-2011, 12:08 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
If the MC fluid level is OK (the most likely cause) make sure the parking brake is adjusted correctly and the switch in the control handle works correctly.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
brake light and dashboard cleaning sailor86 Engineering/ Technical 4 12-29-2009 07:40 AM
Changed brake pads now trac off light and brake warning light stay on Lotusluvver Cavalier Problem Diagnosis 1 06-28-2009 01:17 AM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
2003 Rendezvous Brake Warning Light Stays On George G Rendezvous 3 09-19-2007 12:47 PM
2001 4Runner - Brake warning lights on smithc33 4Runner/GX470 7 08-17-2005 09:05 AM
Tags
brake , dimly , glows , light , warning
