Old 06-25-2009, 09:10 AM
Lotusluvver Lotusluvver is offline
Changed brake pads now trac off light and brake warning light stay on
Anyone know how to fix this? Or what I could have possibly done wrong? The brakes work fine, but the lights are on and the warning beep won't stop beeping when driving! All I did was change the pads!
Old 06-28-2009, 01:17 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Changed brake pads now trac off light and brake warning light stay on
You probably pulled on a wheel speed sensor wire, damaging the wire or connector. It's common for the wires to break where they bend from the constant bending. It's possible the wire was already broken but still contacting and jacking the car up was enough to bend it far enough that it no longer contacts.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
