Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-12-2011, 04:25 PM
DaChevyClassic DaChevyClassic is offline
Battery Gauge Meter
When I hit the brakes I can see my battery gauge meter twitch a little. My battery gauge meter keep waving back and forth when I get off the gas at a low RPM. What this can be?
Old 10-12-2011, 05:11 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Battery Gauge Meter
Could be low alternator output. A little movement when a electrical load is added the system, such as brake lights, head lights, ect...is normal.
Old 10-12-2011, 06:57 PM
j cAT j cAT is offline
have the battery load tested. this can be done free at most auto part stores. make sure the battery connections and cables are clean and free from the green corrosion. also check grounds.
with a voltmeter at the battery measure the voltage with the engine running, no lights,ac etc on. then turn on ac lights heater/ac blower to max and the voltage should not drop.
If the voltage drops or pulses this would indicate a bad regulator/diode assy of the alternator.
the voltage should be 13.5 volts at 100deg f . the voltage at 70 deg f will be about 14.25 volts. this is with a engine at normal operating temperture at idle.
THE VOLTAGE SHOULD NOT VARY WITH RPM OR NORMAL VEHICLE electrical LOADS AS BUILT.
If you have an aftermarket HI POWER sound system this would overload the alternator output ability and you will see a change in voltage.
No Battery Gauge !!! ? rendertrust 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 28 10-04-2006 07:15 PM
Low Battery Gauge Tommy611 Bonneville 2 09-12-2005 08:34 PM
no radio/No battery gauge Sarnia Caravan | Voyager 4 05-17-2005 10:48 PM
Battery Gauge Dropping, Please Help. Mitsu95 3000GT/Stealth 10 09-20-2004 10:32 PM
gauges/meter Grand Am 96 stgeorge Grand AM 1 07-28-2004 12:13 PM
