Old 10-10-2011, 08:26 PM
curtisr57 curtisr57 is offline
P0155 and P0155 p/d: what's the difference?
Hi everyone,
While much help has been posted here on the subject of P0155 errors, my 2003 S10 is showing not only a P0155 error but P0155 p/d (pending) is also appearing. Would this mean I have to replace something other than the Bank 2 sensor 1 O2 sensor?
Thanks a million in advance.
Old 10-11-2011, 03:05 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: P0155 and P0155 p/d: what's the difference?
Originally Posted by curtisr57 View Post
Hi everyone,
Codes come in past, present and or history or pending depending on sanner and computer system.
Pending code is a problem that the computer has detcted and is preparing to set a hard /present code if the problem stays there.
But a code does not say replace the part.
A code points you to a certain problem and usually where the problem is.
Then you need to test out that area to find problem.
Can be a bad part or bad wiring or computer or even some thing else causing like fuel pressue or vacumn leak or engine miss that can make that part act up.
Parts places offer free code scans and the will try to sell you parts for that code.
But do not fall for that.
Just get the free code and the get some good repair information that has the code repair flow chart and go threw the repair flow chart.
MT
Old 10-11-2011, 03:13 AM
MT-2500's Avatar
AF - Advisor
In your case with a 4.3 and a code 155 pretaing to 02 sensor heater circut bank 1 and 2 sensors.
First check would be heater circuit fuse and voltage to it and also ground.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
curtisr57 (10-11-2011)
Turbo and non turbo heads - what's the difference? maddog1001 Maintenance 1 06-18-2009 08:22 PM
IS 200/IS300-what's the difference, will IS200 TRD and TTE parts fit the IS300 eckoman_pdx IS200/IS300/IS350/Altezza 3 06-13-2005 11:13 PM
What's the difference between a the GT and GT-1 trim levels? DaveSev Grand AM 7 06-04-2004 02:02 PM
what's the difference between rps13 and the ps13???? bamer02 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 05-09-2002 08:22 PM
What's the difference between having Drop Spindles in the front and Coils? NassD General Discussion 4 04-21-2002 12:04 AM
