Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-07-2011, 01:05 PM
iceman2 iceman2 is offline
Stick shift won't shift to 2d
2001 Jetta, 110,000 miles, manual transmission; will shift from 1 to 3, 4, and 5, and R, but not 2d; feels like some sort of obstruction in the stick shifter itself. Slight rattle underneath.
Old 10-12-2011, 06:46 PM
denisond3 denisond3 is offline
Re: Stick shift won't shift to 2d
If you are lucky, it may only be a problem with the connection between the shift lever and the transmission. I believe your car has a pair of cables running from shift lever to the top of the trans. These can get stiff with age and corrosion, and there is a plastic part on one of them that is known to break. This stuff is located under the battery box, so is invisible normally.
The other possibility is much less enjoyable. It could be a problem of a bent or cracked shifting fork inside the transmission, or a chunk of a synchro ring that has broken off and is getting in the way. Not only does this require transmission removal to repair, but it carries the danger than a loose piece of metal inside the trans can get jammed between gear teeth - and cause the trans to lock up: In which case depressing in the clutch pedal wont help.
2005 BMW Ci Fake Stick Shift TheSixthSin 3 Series 0 05-06-2010 08:13 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
1993 lude stick hard to shift to 1st gear gelcol Prelude 6 01-23-2007 12:23 PM
HELP!!!!! 94 GT won't won't shift out of overdrive JTKrupa Grand AM 12 06-07-2005 09:47 AM
Throttle stick in between shifts please help 92CamaroRS Camaro Discussions 28 09-07-2004 06:10 PM
