Old 09-07-2004, 03:59 PM
92CamaroRS 92CamaroRS is offline
Exclamation Throttle stick in between shifts please help
I have a 92 camaro 3.1 v6 manual. In between my shifts, when i push the clutch in, the throttle likes to stick open at about 2000 rpm and will stay there for abou5 seconds until it eventually returns back to idle. I had an idle air sensor motor changed but that did not fix the problem. can someone help me?
Old 09-07-2004, 04:00 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Throttle stick in between shifts please help
When you say stick open, Do you mean that the pedal is sticking down? Or the pedal returns and the idle stays up??
1991 Camaro Z28
Old 09-07-2004, 04:01 PM
the pedal returns but the idle stays up
Old 09-07-2004, 04:02 PM
DaMoNe6969's Avatar
alright.. sounds like a bad or misadjusted TPS (throttle position sensor)
Could also be a vacuum leak in your system somewhere.. WHen you rev up the engine, do you ever hear whistling noises??
1991 Camaro Z28
Old 09-07-2004, 04:05 PM
yea i was under the hood and was revving a bit and it was whistling a bit on the passenger side
Old 09-07-2004, 04:10 PM
DaMoNe6969's Avatar
Have someone rev it up a bit and listen through a length of pipe.. Try to pinpoint the whistling noise.. A bad vacumn leak will cause the high idle.. You could also try squirting soap and water on all the hoses and connections (EGR hoses, PCV hoses etc etc) Look for bubbles
1991 Camaro Z28
DaMoNe6969's Avatar
welcome to the forums by the way
1991 Camaro Z28
Old 09-07-2004, 04:13 PM
ok. i actually just looked and there is a fairly large leak from my idle air hose, the hose coming from the beginning of intake into my valve cover
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
if you do plan on changing the TPS, i have some advice. use the right size tool, cause the bolts will
strip out.
Old 09-07-2004, 04:15 PM
DaMoNe6969's Avatar
Re: Re: Throttle stick in between shifts please help
That sounds to me like PCV system?? I could be wrong.. at any rate.. Fix it! lol let us know how that goes for you
1991 Camaro Z28
hey thanks. where exactly is my tps?
Old 09-07-2004, 04:18 PM
DaMoNe6969's Avatar
it'l be on the throttlebody at the end of the throttle shaft.. Kind of a round lookin thing with two small torx screws holding it on and a three or four wire plug in it..
1991 Camaro Z28
Old 09-07-2004, 04:24 PM
ok i removed the tps and there is a spring wrapped around a metal shaft is that supposed to move freely?
Old 09-07-2004, 04:26 PM
DaMoNe6969's Avatar
yeah that should move freely (it should only be able to move in one direction, then return.. but there should be very little resistance..
1991 Camaro Z28
Old 09-07-2004, 04:27 PM
wow. ok because that was half open and when i push it, it doesnt spring back and it also has quite a bit of resistance
