Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-01-2011, 11:59 AM
Josef Stocker Josef Stocker is offline
How to change the LIM gaskets?
Transport 1998 3-4 liter; finally got to the bottom of the LIM to change the gaskets. But the gasket goes behind/in front of the mechanic (suppose these bars serve the valves).
How can I change the gaskets? Do I have to remove these bars and if so, how? I am afraid to change too much. See attached picture of LIM.
Joseph
Old 10-01-2011, 12:14 PM
Jrs3800 Jrs3800 is offline
Re: How to change the LIM gaskets?
Those are Pushrods, you need to remove them, but the intake and exhaust pushrods are different lengths, make sure you reinstall then in the same order you removed them.. You will need to remove the rocker arms to do this..
Also curious, did you get the Fel Pro metal framed gaskets for the replacement?
The Following User Says Thank You to Jrs3800 For This Useful Post:
Josef Stocker (10-01-2011)
Old 10-01-2011, 02:30 PM
No, it looks rather as plastic. I bought it in Sweden, was there in the summer time for a house exchange.
Old 10-02-2011, 10:32 AM
Tech II Tech II is offline
Actually, if you have the special tool to depress the rockers, you don't have to loosen the rockers to remove the rods........but yes, the push rods should be removed, and put back in the SAME ORDER....
The Following User Says Thank You to Tech II For This Useful Post:
Josef Stocker (10-03-2011)
Old 10-10-2011, 03:42 PM
I nearly finish the wok. One tube (most probably vacuum) on the engine backside got off and I don’t know where this tube should be connected to.
Joseph.
Old 10-11-2011, 12:44 PM
rkvons's Avatar
rkvons rkvons is offline
Joseph.
It goes into your valve cover on the back side of the engine. It should have a sorta barbed end that will stick into a grommet and, because it is barbed, will stay in.
http://i486.photobucket.com/albums/r...vons/hose_.jpg
Replacing LIM Gasket TIPS mpit91 Grand AM 5 01-31-2012 02:53 PM
How do I change the head gasket on my 3.8L msm15 Windstar 19 04-06-2008 06:45 PM
How to Change the Head Gasket In 94 Honda Civic EX JohnnyReb454 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 08-17-2006 10:51 PM
Anyone change the manifold gaskets themselves? 99 GAGT Grand AM 2 05-16-2004 08:41 PM
no sparka couple weaks ago i changed the head gasket on my 91 talon tsi awd. before i svnt2onesvnt Off-Topic 0 09-28-2003 07:34 PM
