Old 03-31-2008, 10:35 AM
msm15 msm15 is offline
How do I change the head gasket on my 3.8L - Could it just be a coolent leak
Hi I have a 95 windstar with a bad head gasket I was wondering if anyone had some instructional info as to how to fix it myself. thanks
Old 03-31-2008, 07:31 PM
wiswind wiswind is offline
Re: How do I change the head gasket on my 3.8L
FIRST thing that you will need is a good repair manual.
Alldatadiy is a good online one.
You can go to the AutoZone website and look under "repair information" for a lot of free repair information as well.
BE CAREFUL to look at the information for the 3.8L motor.....they will list the 3.0L and 3.8L.
Also....read VERY carefully torque specifications.......inch pounds (IN/lbs) and Foot pounds (ft/lbs) are 2 very different things.
I ran into a issue using a clicker style IN/lbs torque wrench......so I recommend a beam style for the IN/lbs application.......it is not much force.
I do know that you will need new head gaskets, new head bolts, and new lower intake manifold gaskets.
Head and lower intake manifold gaskets MUST be dry fitted.......don't try to improve upon it by adding any sealant where not called for.
Any sealant that you use MUST be "sensor safe".
The lower intake manifold bolts are re-usable.
I am not sure about the upper intake manifold on the 1995.....as they only used that on the 1995 windstar......maybe similar (or even same as...but don't count on it, the Tauras 3.8L).
I would also get the replacement parts from FORD......they are not very expensive......the major issue is the LABOR.
As I mention in the sticky post "General Windstar Information".......there is a TSB...that says.........
Do NOT use any metal tooling to scrap old gasket material from the alluminum heads or intake manifold......as this will leave small scratches......and coolant will wick in and cause the replacement gasket(s) to fail....this is particularly critical with the 1995 3.8L as they have the smallest gap between the coolant passages and oil/etc......so you don't have much room for error.
There are some solvents that Motorcraft has that you can soak the gasket material with....to soften it.
There are a couple members here who may have done the head gasket job.....and they may chime in with more useful information than I can provide (I'm not a mechanic).
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 03-31-2008, 07:46 PM
tartersauce tartersauce is offline
If your gonna do this yourself, get 2 full days of time.
Day one - drain all your fluids in engine Coolant and Oil. Close the coolant plug in the rad, but leave open the oil pan plug because you will have to flush the pan out once your all back together. Coolant will get into the oil pan.
Other things to change while your apart! Thermostat, fresh coolant, new oil filter, Heater hoses to firewall etc.. look over everthing back there!
Keep everything in order!! Bolts screws etc with the correct Part, and clean every piece. Lable wiring and hoses with masking tape or duck tape with a sharpe. This way you wont get lost going together.
Everything Must be Spotless when going together!! If you cant get the gasket residue off of the Heads, or Block soak them over night with CRC or Gasket remover!! Then the next day, it will be easier on you..
Dont forget a Torque wrench and Get a NAME brand one!! No cheapo one!! You can rent a good one at a parts store if you have too! When torquin, make sure you follow the correct bolt pattern!!
Dont rush!! Have lunch and dinner! dont work tired or in wind rain etc.
Refilling the coolant - You will have to bleed this system a few times to get the air out!
When Done, Have a beer with your friends!
Almost forgot, If your water pump is old or older Change it now while your apart.. Water pump isnt fun at all, and since your apart just do it.. Also the Metal coolant tubes under the intake have rubber seals.. Look for White powder round the edges. If you see that, Change them now.
Make sure your ports for the EGR valve are cleaned and not clogged.. You will see them in the intake..
If you have any conserns just ask..
Ive always cleaned Heads and Engine with Scotch brite pads and some crc. Wipe down with a cloth and windex once your all shined up.. No Oil on surfaces going together!!
Old 03-31-2008, 08:59 PM
Wow thanks for all the help everyone
Old 04-02-2008, 03:03 AM
tripletdaddy tripletdaddy is offline
Be extremely careful not to scratch the block to head surfaces, others have said it can lead to gasket failure. I think tsauce said use Scotchbrite. Not sure what is best to scrape off old gasket, I think you can buy a plastic putty knife scraper at the hardware paint store. It has also been highly recommended to use Ford's gaskets as they supposedly have redesigned them because of the infamous 95, 3.8L failures that you dubiously have, sorry. I'd price shop online Ford parts and locally for the whole set/kit. I have always had my heads pressure tested and surfaced. I guess pressure testing may be debatable if you are 100% certain the gasket ONLY failed. I found a cracked head that way, but a different motor. Does this motor have a lot of mileage? You may want to go the extra mile and redo the valves on each head while you have it in for the other work. Second opinions? Go ahead do plugs and maybe wires as all of that comes off and I think it's ok to put in the back plugs in the back head while it's out. Can't remember if you want them out to turn engine by hand or not. Good time to backflush heater core too. Without looking at it, there may be some shaft seals worth replacing at this time. See what's in the gasket kit before buying something separate.
Old 04-02-2008, 07:11 AM
Yes, if your planning on running the van another 100k or so, Get the valves looked at and cleaned up.. They may need cutting and they may not.. The valve guides are what wears the most, and will wobble the valve seal and wear the valve seat. All depends, on checking heads too. If it Overheated HOT HOT, I would get the heads checked for squareness and crackes. That shouldnt cost much to check either. Our machineshop local, 35 each head for resurface and crack check.. 3cly head..
Common in Gasket overheating..
Also, Use the scotchbrite by hand and dont work in one spot. You can wrap the scotchbrite to a block of wood, the longer the better. 6 in long or so.. This will keep it from diggin into one spot. No air spinners with the scotch pads on the end.. It will really dig into the head, Is a no no..
Old 04-02-2008, 12:19 PM
Re: How do I change the head gasket on my 3.8L - Is it just a coolent leak ?
Thanks for all the help I really appreciate it, but now I am not even so sure it is the Head gasket, I took that car for an hour drive, half hour each way and it rested for about 10 min in between, and for some odd reason the heat miraculously worked well for the first time in a while. through out the drive the engine temp gauge did not really move it stayed all the way at the bottom. when I got home I checked the coolant over flow container, I had poured some coolant in last night and it was gone after that drive, but the radioator hose which usually felt over loaded with pressure, and like it was going to burts was actually fine this time nothing abnormal, the pressure seemed good.
So now I am stuck as to what to do, I had taken the van to two different mechanics and they both said it was the head gasket, I had my mechanic who was servicing the car from the beginning do some tests to confrm that it was a head gasket problem, which he said after the tests that it was.
The car so far has not come close to over heating, the gauge just went up and down, never getting into the red zone and never staying up for more then a second, which might lead to a thermostat problem, if that was the case which one of the mechaincs didnt think it was - why am I loosing so much coolent, I went through almost a whole gallon in one mornings worth of driving ?
there may be a leak I am not sure I will check that out later but is there anything else I am missing - is it possible that this isnt a head gasket problem ?
ALSO TO NOTE: at 134k miles I AM STILL ON THE ORIGINAL HEAD GASKET which adds a little fun to things for a 95 3.8L engine. when I brought the van to both mechanics they were quite shocked at that,
the water pump was changed about 60k miles ago so I guess I have to start looking around to see if there are any other leaks that for some reason the mechanic missed.
any info would be greatly appreciated and really helpfull thanks
Old 04-02-2008, 02:24 PM
Head gaskets cause
White smoke out the tail pipe with loss of coolant.
Overheating from low coolant levels
Ruff running and misfiring
Milky color Oil and Oil Fill cap Light Brown color milk shake looking.
Oil in Coolant Bottle
Coolant can also leak inside the heater box from the Heater core, which is inside under the dash.. If it does leak, it will drain out of the drain tube of the box. This is the same drain as the AC evap when the Ac is running.
Clues are Sweet smelling air with the Heater running. Notice it alot more the first few seconds when you turn on the blower.
Your Thermostat can stick closed which can overheat your engine and force coolant out of the bottle. Stuck Open causes Warm heat, and the engine takes alot longer to warm up.
Coolant has to go somewhere, If you can pinpoint it...
Old 04-02-2008, 06:32 PM
I opened up the radiator and the coolant looked murky/rusty brown, it looks like that in the overflow container as well, the oil however looked fine color wise and all so where does that leave me ?
Old 04-02-2008, 07:26 PM
It just looked like old coolant right? Nothing floatin on top? If its all coolant, and the oil looks good, Like oil.. The last place for it to go If it was a head gasket, is out the tail pipe. It will smoke white.. Like a Mini Cloud..
Do you have Heat in the rear of the van? Drivers side behide near the rear wheel. If you do, there is also coolant lines running back there, with another Heater core.
Old 04-02-2008, 08:33 PM
nope its fairly new coolant, It went through two gallons of coolant in the last 2 weeks, also there is no white smoke, the exhaust is clean, but the coolant looks terrible and when I get out of th carit smells like burnt coolant ?????
Old 04-02-2008, 08:46 PM
HMm.. I would look at your Rad area Back of engine.. If you smell coolant, its gotta be leaking out somewhere!
DO you have rear Heat?
14 quarts of coolant needed for a complete flush if were empty.
Just adding coolant could still just make the new coolant dirty..
No signs of smoke, No ruff running, Oil looks like oil, Kinda odd, you dont have the head gasket signs, just losing coolant. And the windstar has alot of coolant lines, hoses, etc running all over the place. Even Under the van to the back.. Check all of them.
Old 04-02-2008, 11:27 PM
Ok well the end is near, I turned on the heat in the car tonight, - no heat only cold air and the engine temp shot straight up an stayed there, I drove about 5 min or so it, didnt have a choice, it didnt get to the red zone but stayed close to it I pullled over got some more coolant added it into the overflow but it didnt help the car rested for a few, and when I started it up again temp went back up and didnt go back down, turning on the heat to full blast also did nothing with a full resevoir of coolant
Old 04-03-2008, 08:26 AM
I had this happen to a Full size van before, The fins on the waterpump broke off, and wounldnt pump the coolant around..
If your thermostat is stuck, you still will get heat! But if the water pump is broken, its poss, whatever coolant is in the engine is all you have to cool it off. It wont circulate..
Old 04-03-2008, 08:44 AM
As stated.....the coolant is going someplace.
If it is external.....there should be a puddle under the vehicle someplace...
I would take it to a local shop and have them diagnose the source of the leak.....and get it repaired.
Also.....the coolant should be changed every 2 years.
"Long Life" (which did not come in our older windstars) is rated for 5 years.....but even that.....I would change sooner.
Just a flush with a 50/50 mix of coolant and steam distilled water.
1996 3.8L Windstar
