Old 05-15-2004, 07:36 PM
99 GAGT 99 GAGT is offline
Anyone change the manifold gaskets themselves?
I just spent the last three day tearing the engine apart to change the upper & lower intake manifold gaskets on my 1999 Grand Am GT V6. Well when I went to start it, gas was leaking from the fuel rail intake. I can’t seem to get the gas intake tube to sit firmly into the fuel rail. When I pulled the intake tube from the fuel rail I don’t remember seeing an O-ring, but maybe it fell out. Is there an o-ring? Is there a special tool? The Haynes manual isn’t very helpful.
Any tips would be appreciated.
thanks
Old 05-16-2004, 08:10 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Anyone change the manifold gaskets themselves?
thanks
I usually dont remove the fuel lines from the rail, just pull the entire assembly out of the way, but yes I believe there is an "o" ring right there.
Also, did you install the push rods in the proper location? they are 2 different sizes and if they are installed in the wrong position, you will be pulling heads off to replace bent valves.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-16-2004, 08:41 PM
Thanks for the response.
The O-ring must of fallen off when I pulled the fuel intake from the rail. If was very hard to pull out of the rail.
When I removed the push rods I laid them on my bench in the exact order and direction (rocker arm/lifter) as removed.
I’ll head down to the dealer and pick up the o-ring.
Thanks for the help.
