Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-27-2011, 11:40 AM
Zuiun Zuiun is offline
Strange rattle when stopped
My question is about a Mountaineer, but I figured I'd toss it at you guys, too (since they are virtually the same thing)...
I have a '99 Mountaineer (Monterey package, V8 engine, AWD, auto transmission) with approximately 113,000 miles on it. I've had the vehicle since 60,000 miles and so far it hasn't required anything but routine maintenance (oil changes, replacement tires, etc.).
Recently, it's started exhibiting a strange, metallic rattle when I come to a stop. It sounds like sticking a pencil against the blades of a metal fan.
It doesn't do this all the time. And when it does, it will just rattle for maybe a second and then stop. Maybe do it once or twice when stopped when it does it. So far as I can tell, it's never made the noise when the vehicle is in motion (but it hasn't been that long since it started).
I plan to take it in to have it looked at, but since it's not consistently reproducible, I thought I'd toss it to you guys to maybe get an idea of what I can ask my mechanic to look at.
Old 09-27-2011, 12:59 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Strange rattle when stopped
I've responded to the post you put in the Mountaineer forum located here.
-Rod
Old 09-27-2011, 02:44 PM
squekyj squekyj is offline
if its nothing obvious like a cat or loose torque converter bolts have him check the starter drive sometimes those go bad and leave the starter gear out near the flywheel so somethines it hits the flywheel.. seen it several times.
1999 Mountaineer - strange rattle Zuiun Mountaineer 1 09-27-2011 12:58 PM
Rattle/Clanking noise when clutch pedal not depressed Boehlldozer Forester 2 07-17-2011 11:05 PM
Rattling/Clicking Sound When Starting Car jcoberly Mustang Problem Diagnosis 0 07-11-2011 08:52 PM
94 rattling when stopped, started, parked, reverse..?? Melyssa Tercel 0 04-19-2005 01:06 PM
rattling noise when stopped in 95 GA soupkitchen Grand AM 4 03-01-2004 07:44 AM
