Go Back   Automotive Forums Car Chat > Subaru > Forester
Old 07-16-2011, 10:10 PM
Boehlldozer Boehlldozer is offline
Rattle/Clanking noise when clutch pedal not depressed
I just bought an 02' Forester 5 Speed (manual) with 131xxx miles on it. It runs fine but makes a really loud rattling/clanking noise that goes away only during deceleration and when I push the clutch pedal (the noise still remains while the engine is at idle, but it is quieter and a bit more intermittent). At first, I thought it was a rattling heat shield on the exhaust, but when I realized that it goes away every time I push in the clutch, I began to worry that it might be something a bit more serious. I've heard that this symptom could possibly be caused by a bad input shaft bearing on the transmission, but are there any other possibilities? Also, if it is the bearing, what on earth could cause it to go bad??? My biggest fear is that I'll go to all the effort to replace it, only to have the new one fail because I didn't fix the "real" underlying problem. If anyone has any knowledge to shoot at me about this, it would be awesome! Thanks!!!
Old 07-17-2011, 10:34 AM
danielsatur danielsatur is offline
Re: Rattle/Clanking noise when clutch pedal not depressed
It's porbably time for a new clutch kit.
Old 07-17-2011, 11:05 PM
I think you're right...gonna maybe pull the tranny out this week and see what I can find out. What I really wonder though is if it will do any damage to anything if I keep driving the vehicle for the next couple of days. It still drives good, just sounds horrible.
clutch pedal sticks depressed?? chickyricky F-Body Problem Diagnosis 4 12-06-2007 06:23 PM
2001 makes noise when clutch is not engaged Adolfoj CR-V 1 02-28-2006 06:00 PM
Noise when clutch pedal is push in... NateS Eclipse Problem Diagnosis 2 09-14-2005 07:41 PM
TDi Z1 engine direction indicator stops flashing when brake pedal is depressed kali Golf 1 04-13-2004 05:03 PM
2000 Explorer revs when clutch pedal depressed MattBG20t Explorer | Explorer Sport Trac 0 03-17-2004 07:34 PM
Tags
clutch , noise , problem , rattling , transmission
