Old 09-23-2011, 09:19 AM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
2001 rear shock help
The rear shocks on my '01 are shot (leaking). I replaced them in 2003 without any problems. I can get the lower bolts out but now the uppers are just spinning in place. The nut on the backside (has a small bracket on it) is just getting pushed out. How the heck do I get those bolts out? Thanks.
*Twin Cities MN*
Old 09-24-2011, 06:00 PM
wiswind wiswind is offline
Re: 2001 rear shock help
I don't know what to offer, I changed the rear shocks on my '96 two times over 10 years, and did not have a problem.
I'm guessing that you cannot get a wrench onto the back side......
Have you tried jamming a pry bar in to keep the back side from turning?
After you get them off, maybe look into a nut instead of the clip.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 09-24-2011, 07:35 PM
12Ounce 12Ounce is offline
Can the bolt-head be ground off? I have this same task facing me, for the first time, on my '99 ... so I may run into the same problem.
Old 09-25-2011, 03:37 AM
After 3 hours of trying to figure it out I decided to cut the shocks off. I didn't want to do this mainly because they had a lifetime warranty (Monroes) and I wasn't sure that Napa would exchange them (they did). The main problem was the upper through bolt was seized inside the shock bushing/spacer thus I couldn't pull the bolt out. Used a sawzall to cut the shock rod and then used a Dremel with a cutoff wheel to cut open the top part of the shock mount. Once the shock was off all that was left was the bushing/spacer and the shock bolt. I used a small pipe wrench to hold the spacer while I used the ratchet to spin the bolt out. What a frakking pain in the rear. I went to the dealer and got new bolts and J-nuts and exchanged the shocks for new ones. All in all I spent 7 hours working on it .
Oh, these are the shocks I'm using.
*Twin Cities MN*
Overheating 2001 CMFan Grand Prix 59 04-15-2010 09:40 AM
2001 Aztec rear shocks tgrudzin Aztek 0 11-16-2007 01:32 PM
rear shocks help 97redtbird Thunderbird 1 10-01-2005 10:39 AM
Rear Shocks on a 98' Sport, HELP PLEASE... YoJimboRyuu Explorer | Explorer Sport Trac 0 12-20-2004 01:55 PM
install rear shocks-help CamaroCaren Camaro Discussions 3 06-13-2004 02:09 PM
