Old 09-15-2011, 11:30 AM
jayjp200 jayjp200 is offline
98 windstar 3.8 liter - IAC question
Hello,
I have a question for the Idle Air Control valve for my 98 windstar.
The idle has been a little rough after the engine warms up.
If I disconnect the connector on the IAC, the engine revs down a bit and then come to normal idle and continuous running.
When IAC is disconnected - shall the engine not stop?
How do I test my IAC on Windstar.
PLease reply.
Old 09-15-2011, 11:38 AM
phil-l phil-l is offline
Re: 98 windstar 3.8 liter - IAC question
When it comes to Windstar IAC valves, I'm a believer in cleaning them first. It's so quick and easy to do, there's little excuse to put it off. It will probably take longer to read the procedure than it will to do it:
http://leckemby.net/windstar/windstar02.html
If cleaning doesn't solve the idle problem, the valve probably needs replacing - or there's something else going on.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 09-19-2011, 10:07 AM
kafkacell kafkacell is offline
Fooling around
Disconnecting IAC valve SHOULD stall the van. If not then you must replace it.
First try cleaning it, is really easy. Just use carb cleaner first. Last time I cleaned mine I fill it up to the top with carb cleaner and leave it for 15 minutes to remove dirtyness.
Then I use WD-40 to make it move freely, just clean the excess and you are done to go.
Clear OBD codes before starting the van. Then PCM should adjust IAC valve to work with the engine.
You only need a socket 8 mm to remove it.
Hyundai Elantra 2001 GLS
YOU ONLY
NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND
SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
The Following User Says Thank You to kafkacell For This Useful Post:
jayjp200 (09-20-2011)
98 windstar 3.8 liter - P0402 code problem jayjp200 Windstar 4 06-24-2010 08:06 PM
98 windstar 3.8 liter instrument panel lights jayjp200 Windstar 1 02-21-2010 01:06 PM
3.8 head changes. help? thunderbirdcoupe89 Thunderbird 2 12-10-2009 11:43 AM
2000 windstar 3.8 engine out of balance walkmanner Windstar 4 03-01-2009 02:04 PM
rear spark plugs 98 windstar 3.8 liter 30fords Windstar 6 04-26-2005 08:24 PM
