Old 09-15-2011, 10:26 AM
nappeal nappeal is offline
98 not taking gas & loud w heater on...
Like I said, my tank isn't accepting gas MOST of the time. The fuel pressure sensor is bad making the engine light come on & the gas gauge not work, so I count my miles. I'll know damn well after my miles that my car needs gas, but when I fuel up, it'll stop the gas pump & eventually spit gas back @ me. Its been doing it a lot more lately, and its pissing me off bc I'm having to make frequent stops to the station lol does it sound like the pressure sensor or maybe a bad or clogged filter? Also, I've had my heat on more recently and as it gets colder outside, my engine makes a nasty squeal when the heat goes on. I'm assuming its the belt; the manifold gasket was replaced about 3 months ago, and the belt was replaced then, so I know its a good belt, but we had to replace the power steering pump a couple weeks ago, so it may not have been tightened w that work. The AC compressor is out, so obviously no Ac, but the clutch still works so IDK its the compressor. I've put a lot of work in on this $ pit over the last few months, so if someone can help give me some info so I can avoid the shop again I'd appreciate it!
Old 09-15-2011, 11:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 not taking gas & loud w heater on...
Most iof your problems are all seperate probems.
What is IDK compresser?
Does it make noise defrost or ac or vent on just heater turned on ?
Unplug compresser and see if you still have belt noise.
Gas gauge works off of pump sending unit.
Check grounds and ohm restiance on wire going to sending unit.
Is tank pressure gauge getting voltage in and out of it?
What is the code no on it.
On not taking gas check vent solenoid or vent tube in filler neck.
Has tank been removed before gas taking problem?
MT
01 Jimmy not taking gas! emissions or fuel system problem? belle78 Problem Diagnosis 3 08-09-2009 08:36 AM
Help gas gauge does not work right and is not taking gas well!!! spflick Taurus | Taurus Wagon 9 08-05-2007 03:21 PM
help gasguagedoes not work and will not take gas hardly!!!!! spflick Sable 0 07-13-2007 11:43 PM
Type of Gas & door speakers on 94 lesabre T_MaK_510 LeSabre 2 07-11-2007 10:20 AM
1999 Alero will not take gas oldbills Alero 4 02-25-2007 11:13 PM
