Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-13-2011, 06:28 PM
bethanyam bethanyam is offline
1998 Ford Contour SE Pulling to the left HELP please!
I have a 98 contour that is pulling to the left ONLY when braking. (and by pulling...i mean it throws the whole car to the left and then shifts back right when you let off the brake.)
The front and back brakes have been changed (and are in the proper places)
All new front brake hoses, the brake fluid is coming out of them fine.
New wheel cylinders on the back.
The calipers have been rebuilt TWICE.
It does NOT pull at all when using the rear brakes (ie emergency brake)
When the car is 1st started it does not pull at all....After it is driven it starts to pull and gets worse the longer/farther it is driven.
The left rear tire is almost bald from it pulling so bad.
When I stop the front left wheel is the hottest of the two front if that matters.
PLEASE any ideas of what to check next will be VERY appreciated!!!
Thanks,
Bethany
Old 09-24-2011, 06:26 PM
Re: 1998 Ford Contour SE Pulling to the left HELP please!
Just an update this ended up being a bad bushing in the lower control arm.
Old 02-12-2015, 08:22 PM
FUKENEH FUKENEH is offline
thanks for the info. i have the same problem, but to the right when i brake. Time saver right here!
1998 Ford Contour Fuse Diagram junbug178 Contour 6 01-22-2010 01:07 PM
1998 ford contour/transmission Glenn1962 Contour 7 03-09-2005 11:13 AM
1998 Ford Contour Fuse Box mijimicah Contour 2 12-15-2004 01:20 AM
1998 Ford Contour ChristopherBrown Contour 7 09-26-2004 03:54 PM
